LSi15s Carpet spikes on Hardwood floors
Hey guys,
I'm moving into a house with hardwood floors and I'm not sure what is the best way to couple the speakers to the floor. Heres what I could come up with, please comment:
1. Continue using the polk carpet spikes, but also buy eight brass isolation pads to protect the wood floor from the spikes.
2. Continue using the polk carpet spikes and buy two slate/granite bases.
3. Remove the carpet spikes and use the rubber feet that came with the lsi15s. I would use washers to adjust the tilt back.
Vandersteen 3a Sigs
Music Reference RM-200
Hovland HP-100
VPI Scout w/ Benz Ace
Rotel RCD-1072
Cardas Golden Reference Speaker Cables
Cardas Golden Reference Interconnects
Cardas Golden Power Cords
PS Audio UPC-200HB
Black Diamond Racing Isolation
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Post edited by cbl117 on
option 3 would be the way to would go.engtaz
As indicated above.Michael
NORTH of 60° -
If I go with option 3 will the speakers have enough isolation from the floor? The reason I ask is because theres a crawl space under the floors. Will that cause any unwanted resonances?2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Black Diamond Racing Isolation -
Only you will know what it sounds like on that floor. You have the rubber feet so throw them on. Good luck.Michael
NORTH of 60° -
Don't you just slip the rubber feet over the spikes and turn the spikes to level things out? Maybe the newer Lsi15s are different, I don't know. I have the older ones.3. Remove the carpet spikes and use the rubber feet that came with the lsi15s. I would use washers to adjust the tilt back. -
option 2 is what they do out here in Japan allot. Looks pretty classy with the right color, however I dont know the benefits of it.Shoot the jumper.....................BALLIN.............!!!!!
Option 1.
De-couple, use brass footers. You will find less bass energy transferred to the floor, and the result should be cleaner, more articulate bass with better attack and fast(er) decay.
Cheers,
In my experience, yes. The sub floor sounds as if it is a radiator. This can get quite annoying. Some are worse than others depending on build quality, supports, insulation and thickness of flooring.cbl117 wrote:The reason I ask is because theres a crawl space under the floors. Will that cause any unwanted resonances?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Option 1.
Cheers,
Russ
Thanks russ I said that completely backwards. I want to de-couple the speakers to the floor. On a sidenote, I'm soo excited to get into my own place. Now I can pump up the jams:D Just wait, I'll be asking for a bigger amp in the next few months.:D2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Option 1.
Cheers,
Russ
The force is strong with Russ. I agree.
V -
can you fill your stands with buckshot?
you will need something like buckshot or sand to deter the resonance on those hardwood floors. -
Wow man, just... wow.
I suppose we were all there once.
I doubt the LSi15's are on stands.
One more like this mox and I'm giving you a cluepon.
Russman said it best. Word up. -
you mean you have never heard of filling speaker stands with ball bearings or buckshot?
mox the lsi15s are towers. They have no stands. I could fill my power ports with sand, but then I'd own a $100 subwoofer from ebay...2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Option 1 first, option 2 second.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I wasnt aware you owned 15s. Thats too bad about your situation.
After listening to music echoing off a wooden floor for a few days, you will feel like you own $100 speakers. -
How about GRAMMA monitor isolation pads?
http://www.musiciansfriend.com/product/Auralex-Gramma-Amp-Isolation-Riser?sku=422640 -
Cool idea but way too big for my room. Those suckers are 2 feet long!2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
