Help a Newbie! Hooking up RM-6750s
KennyL
KennyL Posts: 1
edited July 2007 in Speakers
I bought this 5.1 speaker system, and want to hook it up to an onkyo 7.1 receiver. My assumption is I hook up the fronts to the front "A" system, the subwoofer to the subwoofer RCA. So far, fairly obvious. Where do the surrounds go? My assumption is the "Surround" posts, leaving the "surround back" posts alone.
Correct?
Thanks in advance.
Kenny
Post edited by KennyL on
  • engtaz
    engtaz Posts: 7,669
    edited July 2007
    Correct, but you left out talking about your center
    engtaz
  • kennyl_98
    kennyl_98 Posts: 1
    edited July 2007
    Your info was all I needed. You're right, I didn't mention the center speaker (because that part of the equasion was fairly self-explanatory). Thanks again. The speakers are working and they sound terrific.
  • seeclear
    seeclear Posts: 1,244
    edited July 2007
    Make sure you set the surround back speakers to "NONE" in the "Speaker Config" setup menu.
    Just curious, are you going to make a new username for every single post you make here?:eek: :eek:
    :D:D:D:D:D:D:D:D:D
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
