Bridged RMS vs RMS
KiiNG 0F SWAG
Hey... Yea I Jus Wanted To Kno Whats The Difference Between Bridged RMS vs RMS Power... And Which Would Be Better To Use Because Im Gettin A Sub Thats Peak Handlin Is 1500 Watts And Tha Amps RMS Is 900 @ 4OHMs But The Bridged Is 1500 @2OHMs... Jus Wanna Kno The Difference And How Would I Bridge If Its Better??
Thank U
Thank U
Post edited by KiiNG 0F SWAG on
Bridged means its combing channels. How many watts is the sub rated for continuously?
May I ask what amp it is.Except for maybe some car amplifiers it is very unusual for an amplifier to have the capability to drive a 2 ohm load in bridged mode.Testing
Testing
Testing -
The Recommended RMS Is 500... Its The Eclipse SW7200 12" -
The Amp Is Boss Riot GT2500D... Its A Mono Amp Too... If That Makes A Difference At All -
1st. you can't bridge a mono amp. There are some you can strap together(ie. using 2 amps on one speaker for more power).
2nd. Boss only makes the best fire starters in the world, and they label them as amps, stay away. -
dudeinaroom wrote: »Boss only makes the best fire starters in the world, and they label them as amps, stay away.
So there not 2 ohm stable :rolleyes: :eek: :eek:
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote: »So there not 2 ohm stable :rolleyes: :eek: :eek:
It probably is, but I've seen to many boss amps either smoke, or cause a fire. They are mass produced low quality amps.
