Polk Atrium60
Systems
Systems Posts: 14,873
edited July 2007 in Speakers
I’m looking for outside speakers in the next few months when my basement is finished. I have the wire run now for a b channel for some toons when I’m working outside. Anyone have any experience with the Atrium60. I would probably run them off my Onkyo Amp (100 WPC).
Testing
Testing
Testing
  • zacgo1
    zacgo1 Posts: 25
    edited July 2007
    I haven't heard the 60, but I run a pair of Atrium 65SDI speakers which are pretty similar. I really like them a lot. I would compare them to RTI4s, maybe with a bit stronger bass. They are a little on the bright side, even for Polks. But overall I am really happy.
    They do seem a little tougher to drive than other speakers I have had but even so I think you will be fine your Onkyo. I sometimes need to go to -2 db on my Denon. If you do get them and try them with and without an amp I would be really curious to hear if the amp made a big difference. I have been getting more and more tempted to get seperates.
    BTW, check out this thread: http://www.polkaudio.com/forums/showthread.php?t=53400
    Zacgo1
    Mains: Polk RTi8
    Center: Polk CSi5
    Surround: Polk RTi4
    Sub: SVS PB10-ISD
    Outdoors: Polk Atrium 65SDI
    Receiver: Denon AVR-1907
    TV: 56" JVC HD-56G787
    Game Console and MP3 Streaming: Xbox 360
    Remote: Harmony 880
  • Systems
    edited July 2007
    Cool! Thanks!
    Testing
    Testing
    Testing
