5 or 7 channel with RTi12 bi-amp?
I am in the process of upgrading my system and am either going with on Outlaw 7500 or 7700. I will be using my Onkyo TX-NR900 as a pre/pro for the moment. I'd like to bi-amp the RTi12's using 4 of the amp channels. With the 7500 I'd use the last channel for the CSi5 and then let the AVR run my two FXi3's. With the 7700 all speakers would be run off of the amp leaving the AVR purely as a pre/pro.
My concern with the 7500 is that the FXi3's will be significantly underpowered even though only about 15% of the sound typically comes from them in HT.
Thoughts?
Thoughts?
A lack of planning on your part does not constitute an emergency on my part...
Post edited by RVJII on
Both of those amps are capable of driving all your speakers just fine. There is no need to bi-amp!
One of the whole reasons to get at least 200wpc is to skip making things complicated & adding extra wires.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
