15" sealed Rythmik Sub?
I've been doing a lot of searching in various forums on the Rythmik subs. There are a lot of good reviews, but mostly on the 12" sealed and vented, and the 15" vented but nothing on the 15" sealed. Has anyone built one or heard one (sealed)? I will be moving and the room is fairly large and open and high ceilings. I really like punch out of a sub for music (90 music/10 movies) which, from what I understand, the 12" sealed has but I need to move more air in the big room w/ the 15 and I will just switch to my def tech for movies if the rythmic I choose doesnt sound as good for movies. If it does turn out good for music I may build another and run 2-15's. I just dont want to spend the extra $ on a 15" sealed and lose the punch the 12 delivers. Also I dont see much on Def Tech subs in the forums either. Are they junk? Got mine about 6yrs ago when just starting out and didnt do any research.
Thanks for any info or direction.
Brett
Brett
Brett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub
Heard good things about Rythmik also.
Try this forum: http://www.diyaudio.com/forums/showthread.php?s=&threadid=96345&perpage=10&highlight=&pagenumber=3
Good luck
DaveTime is the best teacher. Unfortunately it kills all its students. -
Build two 15" sealed subs for music. If you like them for HT, then ditch the Def Tech.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
