need some advise
noobaslt
i can bouth silversonic 2200 amp for just 80 $ but i have no idea how much power it pushing ? can anybody find it?
Pioneer DEH-P880PRS
db6501
more coming soon.... :rolleyes:
db6501
Post edited by noobaslt on
According to the first result of a Google search of Silversonic 2200:
http://www.satkaikkonen.com/product_details.php?p=61
The power is:
4x275W / 2x525W RMS @ 4Ohm
4x550W / 2x1050W MAX @ 4Ohm
Brian -
and one more question should i bouth it???Pioneer DEH-P880PRS
db6501
more coming soon.... :rolleyes: -
sure, you can bouth if you want, but I probably would not buy it, that's pretty cheap for that much wattage.
dudeinaroom wrote: »sure, you can bouth if you want, but I probably would not buy it, that's pretty cheap for that much wattage.
As in...I wouldn't expect any performance out of that amp- the ratings are probably "max" and unrealistic. Probably not worth having- looks to be garbage. -
Stay away from that thing.....you could do much better on ebay.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
