RM6880 Sub Question
lax4u
lax4u Posts: 1
edited July 2007 in Speakers
RM6880 sub has two input on back L & R. I have Onkyo TX SR605 receiver wich has only one out put for sub.which one should i connect Left or Right? Also if i used Y woofer cable to connect to both, will it make any difference in sound quality or loudness?
Post edited by lax4u on
  • seeclear
    seeclear Posts: 1,243
    edited July 2007
    Opinions here seem to vary whether it would make any difference or not. You can hook up to either input, or Y it to both. Try it both ways and see which sounds better to you. :D
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • swegyptian
    swegyptian Posts: 316
    edited July 2007
    I would be suprised if there were a difference. :)
