Center channel and rears
flr057
flr057 Posts: 20
If I have a large center (Klipsch Academy) and two Polk RT35's as rears (also large) shouldn't I call them 'large' in my set Yamaha's set up?
Or in the classic HT 5.1 set up, I should call the front mains (again they're large but called small) and call the center and rear channel speakers small.
Hence, the sub carries all bass below 90 hz.
If I haven't lost you, my real question is; Since all of these speakers are capable of carrying bass from 90 hz down to around 40, aren't we losing a lot sound especially from the center channel?
Thanks for any input.
Yamaha RX-V995
HK PA 5800
Klipsch KLF-10 (front)
Klipsch Academy (center)
Polk Rt- (rears)
SVS - PC12- NSD
Post edited by flr057 on
  • john22614
    john22614 Posts: 214
    edited July 2007
    It is generally best to set all of your speakers to small and let the sub handle everything below 90hz. This provides maximum headroom and current to your mid base and up speaker performance and allows the sub to do what it does best. This will give you undistorted deep bass and, when properly calibrated, will blend in perfectly with the rest of your sound.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
  • McCelery
    McCelery Posts: 123
    edited July 2007
    I have my center and rears set to small but crossed at 60Hz so they're still handling some of the tamer bass. I found the surround effects and voices were much more palatable this way then when I had them crossed at 90Hz or 120Hz.
  • Early B.
    Early B. Posts: 7,900
    edited July 2007
    Experiment with the settings.
    "God grooves with tubes."
