Newbie Needs Help From The Experts!
64met
64met Posts: 63
edited July 2007 in Speakers
OK here is my question/situation... unfortunately years ago I was talked into the Bose Accoustmas 15 system. I have since learned the error of my ways and have added the monitor 50's and Polk Sub 404. Realizing, most of the sound comes from the CC I now want to add the Polk CS 1 or 2. Due to my budget right now and space issues I will be forced to stay with the Bose as my rears. I know this all sounds bizarre but that is where I am. Does anyone know since the amplifier that powers my Bose needs to say connected for my rears to work; by disconnecting the Center from the "system" will it cause any damage or overloading of the rears? Can't really post this on a Bose site so I thought someone here could help. BTW... When I added the Polk 50s and sub I kept my Bose system all connected.
Thanks in advance!
My receiver is the HK 7300
Dedicated HT: JVC RS-2 Proj; Carada 104' fixed screen; Yamaha RXZ-7; Outlaw 7 X 200; Toshiba HDXA2; Blu Ray Panasonic 30; Polk Rti10's;
Csi5; Fxi3 and Outlaw LFM1X Sub; RTi Universal RC
  • warlocks1
    warlocks1 Posts: 1,252
    edited July 2007
    I would leave everything connected. The bose running with the Polk's should sound good.
    Does your HK allow B channels to run in surround modes? If so, hook the Polk's to B and leave the Bose hooked up like normal.
    I don't think you will hurt the Bose by disconnecting the fronts and center. But, it is Bose and I have no idea if they wire their systems in a different way. Call Bose.
