Shanling CDP, just another pretty face?
del44
del44 Posts: 686
edited July 2007 in 2 Channel Audio
The Shanling cdp's look cool but do they sound as good as they look. I'm looking into the SCD-T200. Because I wanted a player that will also do SACD. Was hoping someone might have or have listened to one. I'm looking to buy used. Thanks.
Post edited by del44 on
    VR3 Posts: 29,429
    edited July 2007
    Shanlings are solid performers - I really like mine...
    With their looks, they give you an incredibly solid build. Mine is made with like 1/4" thick aluminum all around...
    treitz3 Posts: 19,992
    edited July 2007
    I thought they didn't play SACD?
  • del44
    del44 Posts: 686
    edited July 2007
  • Early B.
    Early B. Posts: 7,900
    edited July 2007
    Shanling makes very good sounding gear.
    "God grooves with tubes."
  • schwarcw
    schwarcw Posts: 7,358
    edited July 2007
    You don't get many choices for a tube CDP that does SACD. The Shanling is supposed to be good from what I read, I've never heard one. A Modwright Sony or Denon universal player would be another good choice. I've got a Modwright Sony 999ES that I got from a fellow forum member that sounds great. I've never heard the Modwright Denon. The Denon would also do DVD-A, which none of the Sony products will do.
    Good luck!
    Carl
  • schwarcw
    edited July 2007
    Zero wrote: »
    If you want to step into a solid machined valve piece that supports SACD - picking up a used Shanling like the one Sid's got for sale is a safe bet.
    Sean, I don't think Sid's supports SACD, I think HDCD and redbook.
    Carl
    Carl
  • Shizelbs
    Shizelbs Posts: 7,433
    edited July 2007
    The 100 does not do SACD. The 200 does though. The 200 looks just like the 100, but the main body is about twice as thick.
    I have the Shanling 100. It is excellent. It was a huge step up from my previous dedicated CDP and DAC combo. I highly recommend the 100, and I personally would jump at the chance to have the 200 and SACD playback.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited July 2007
    I think the Shanling gear is ugly as sin. Way too George Jetson for me.
    As far as build, sound, etc - I can't really say - I've only spent a dozen hours or so with a CDP and some Tube Monoblocks.
    Cheers,
    Russ
  • danger boy
    danger boy Posts: 15,722
    edited July 2007
    so has anyone rolled any tubes into the Shanling CDP? or are you all that have them using stock tubes? just curious
    PolkFest 2012, who's going>?
  • del44
    del44 Posts: 686
    edited July 2007
    I have a DVD-Audio player, but no SACD player. I was hoping that the Shanling would really make regular CD's sound good. The SACD option would be a bonus. Right now I'm using my 8 year old Sony 200 disc player. I bought it new for about $175. So what does that tell you.
    As far as the tube section is concerned. Would it sound better using a tube pre and tube power amp? Or would it still sound good with ss gear.
  • Shizelbs
    edited July 2007
    I use mine with SS amp, and its awesome. I actually prefer the SS output of the CDP to that of the tube stage.
