SDA SRS Speakers on the Bay
gadgetdad
No Affiliation
http://cgi.ebay.com/Polk-Audio-SDA-SRS-Speakers_W0QQitemZ280132488482QQihZ018QQcategoryZ14993QQrdZ1QQcmdZViewItem
TOY INVENTORY
TOSHIBA 65HM167 (DLP)
ONKYO TX-SR603X (AVR)
Logitech Harmony 880 (REMOTE)
PureAV PF60 (POWER)
polkaudio CS400i (CENTER)
polkaudio RT1000i (MAINS)
polkaudio FX300i (SURROUNDS)
polkaudio RT25i (REARS)
polkaudio PSW350 (SUB)
DefTech SuperCube I (SUB)
Post edited by gadgetdad on
maybe you will win them for $5.50
I'm the highest bidder!!!!
Is that water damage on the bottom of the speaker??
Jim -
Am I mistaking, or are those 2 different speakers. 1 has either SL3000 tweeters, and the other has SL2000...also, the bolt pattern on the X-over plate is different.
You may be right. The seller needs to post some better pictures. Could be a 1.2tl and something else.
and what did he say. that pair looks fishy to me. i would check them out good
He apologized and said he couldn't get both speakers in the picture so he took one from another source (the 1.2tl). He stated that they are indeed SDA SRS and not the TL model.
