Need Some Help/ Advice!
Ok here is the deal.... I own the HK 7300 and unfortunately years ago was talked into the Bose Accoustmas 15. Recently however, I added a polk sub and the monitor 50's to my system. The sound from the 50's is great. However, I primarily use my system for movie watching and desire the deep bass I am not receiving now. I am considering upgrading my 50's and adding a Center Channel with Polk Rears as well. Can anyone offer suggestions on a good, quality set of speakers that would work well with my HK7300? I was trying to spend no more than $1,500 total. Thanks in advance for your help!
Dedicated HT: JVC RS-2 Proj; Carada 104' fixed screen; Yamaha RXZ-7; Outlaw 7 X 200; Toshiba HDXA2; Blu Ray Panasonic 30; Polk Rti10's;
Csi5; Fxi3 and Outlaw LFM1X Sub; RTi Universal RC
Post edited by 64met on
In HT mode the sub will be doing the most bass, so either you need a larger sub for the room size.
Or you have the AVR setup mis-adjusted the L&R speakers should be set as small for starters...
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Other then that Welcome to the Club
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
