MMC6500 connection to crossover help
dmode101
I just install my Momo MMC6500 components and Im not sure if they are hooked up correctly. The instructions in the manual were not that clear to me about the hookups to the crossover. SO, from the mid speaker, does this go to the crossover INPUT -/+ or the crossover OUTPUT -/+? The manual said to install the tweeters to the crossover OUTPUT +/-, but didnt specify for the mid. I am assuming to connect both the mid and tweeter to the OUTPUT side of the crossover. Then from the crossover INPUT, connect the Mid Woofer input to the amp? Sounds backward to me, but is this correct? Thanks for your assistance.
