bi-amping rti's question??
BOBBYFRESCO
BOBBYFRESCO Posts: 5
edited July 2007 in Speakers
:confused: Hey! Has Anyone Compared The Rti 12 Vs The Lsi's Wondering What Was The Difference Is, You Know Im Only Pushing Rti-12 With The Yamaha Rxv25oo 5 Surround Maybe At 140ch 25%, Also Guys I Had A Question I Want To Push My Rti's At Least With 100more Watts Plus My Sub Too.. Its Velodyne 10' 385watts, How?? And What?? Amp Should I Buy For 100watts, How Do I Install It, The Rti's Are Bi-amped And Im Not Really Sure What That Means..
Also My Sub Question? My Velodyne Dsp10 Sub Is 385watts Digital, Do I Add That Additional Wattage When I Add An Amp Or Reciever Totaled Or Does The 385w Power Onlycome From The Rms Amp From The Sub?? Not Sure How To Calculate The Power Wattage When Adding Power Or Recievers Confused!! Bobbyfresco Boys! Keep Rockking..thanks Guys Ill Be Online On And Off, So Holla At Me..:rolleyes:
Post edited by BOBBYFRESCO on
  • Systems
    Systems Posts: 14,873
    edited July 2007
    Right now I have my Onkyo (100w) going to the top of my rti12's and my Onkyo avr going to the bottom (135w). The tops sound great. The bottoms can only be hard when I really turn it up, 135W is not enough. I have 2 outlaw monoblocks coming now for the bottom to drive them at 200W. Everyone around here have always said that you need power for RTI12's and I believe them now.
    Testing
    Testing
    Testing
  • millerman 3732
    millerman 3732 Posts: 1,488
    edited July 2007
    Have you tried turning up the levels in the AVR for the bottom to match the top alittle closer? That is if you have a seperate level control for the bottom
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • Pepi28
    Pepi28 Posts: 248
    edited July 2007
    You cant add anymore power to your sub because it has an amp built in. How are your 12's bi-amped if you dont know what that means. Bi-amped is 2 pairs of speaker wire going to each speaker and coming from 2 pos. and 2 neg. terminals on your amp or receiver (meaning 4 channels are used up on them). If you want more watts for your RTi's I suggest you get a seperate amp with at least 200 watts per chan. at 8ohms.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • bob1029
    bob1029 Posts: 20
    edited July 2007
    Apparently 500 watts is right about the sweet spot for powering the bottom end of the rti12s. Im using a behringer ep2500, and I can go full-bore with it with minimal concern (cutoff filters enabled).
    Sharp Aquos 32d62u
    Onkyo TX-NR901
    Behringer EP2500 - RTi12 - CSi5 - FXi5
    Sonosub 700L tuned flat @ 14hZ
