A frustrating Momo listen problem
Systems
Systems Posts: 14,873
edited October 2002 in Car Audio & Electronics
I am in the market to buy some good component speakers - trouble is I have searched all of TEN Circuit City and indie stores w/ NO LUCK in finding a single store w/ Momo's on display! Since I made the mistake of not listening last time I bought my harsh Kappa's, I will NOT make it again. Can ANYONE help me find a SINGLE store w/in 50 miles of Cleveland, OH that has them on display, cuz should it be THIS hard to simply demo a speaker?!
The CC in Elyria had them hooked up all wrong, w/no bass at all, were little help and were the ONLY place I could find that had a single demo up!! HELP PLEASE, lest I be stuck w/ overly bright Kappas!
Testing
Testing
Testing
  • Systems
    edited September 2002
    Since the recall a few months ago - we are now waiting for replensihment from Polk Audio's distributor. I am expecting them in my store store before the end of the month. But this is just speculation.
    Circuit City Guy
    Testing
    Testing
    Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited October 2002
    Kevin --- the momo tweeter sounds almost identical to the db / dx tweet --- so they're the aboslute opposite of harsh -- bright w/o bite
    the woofer i dont know about ... it is different... but the tweet is the same.
    don't know if that helps, but if you can't find a demo, its the best psuedo demo i can give ya. :o)
    The Artist formerly known as PoweredByDodge
