Titan XL Sub any thoughts or options??
engtaz
engtaz Posts: 7,664
edited June 2007 in Speakers
What are someone's thoughts and opinions of this sub?
engtaz
Post edited by engtaz on
  • Early B.
    Early B. Posts: 7,900
    edited June 2007
    Haven't heard one, but they're supposed to be excellent subs. They look nice, too. Buy it.
    "God grooves with tubes."
  • pearsall001
    pearsall001 Posts: 5,093
    edited June 2007
    I've been kicking around the idea of trying either the Force or the Titan model myself. From what I've read...they are excellent subs for music & movies. It sounds like they're a cut above the popular brands (svs, hsu...etc.)you hear about.They are especially know for their seemless integration with your mains. I just never got around to giving one a try. ACI does have a nice return policy. Give it a shot & let us know how you like it. I don't recall hearing any feedback on them in this forum. The audiocircle forum has a ton of fan base.
  • engtaz
    engtaz Posts: 7,664
    edited June 2007
    Has anyone owned them or demoed them?
    engtaz
  • pearsall001
    edited June 2007
    engtaz wrote: »
    We're waiting for you to be the first to pull the trigger & report back with your findings!! :D
  • Early B.
    edited June 2007
    engtaz --
    Have you purchased it yet?
  • engtaz
    engtaz Posts: 7,664
    edited June 2007
    You guys are funny. I don't purchase anything without researching it first and that's what I am doing now.
    engtaz
  • Early B.
    edited June 2007
    There are a few subwoofer brands where you can't go wrong -- Hsu, SVS, VMPS, etc. Add ACI to the list.
  • engtaz
    engtaz Posts: 7,664
    edited June 2007
    Or Ben's version of a Sona sub
    engtaz
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    engtaz wrote: »
    Over kill. I wouldn't exactly recommend it for a house unless you had a big room. When I have it cranked, or my new SDA customs you can actually see the windows flex 60' away through 2 rooms(cheap single pane windows). I have not yet turned both on at the same time, and cranked them. Also No WAF here at all.
    Ben
  • engtaz
    engtaz Posts: 7,664
    edited June 2007
    Too funny Ben. "Also No WAF here at all."
    engtaz
