Confused about Polk brands?
kcrossley
kcrossley Posts: 12
edited June 2007 in Speakers
I've decided to purchase a set of Polk in-wall speakers for my home theatre system, but I'm a little confused about the various brands they offer. Unfortunately, there isn't a local distributor who has them setup, so I kinda need to go with the advice of others that may have heard them.
With that said, is there a discernible difference between the Polk RC, SC, TC and LC series? Which series is preferred most by audiophiles and why?
Also, what subwoofer should I pair with a Polk system?
Thanks,
Kelly
Post edited by kcrossley on
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    Welcome to Club Polk Kelly. I don't have any experience with in walls, but I am sure someone will chime in with some good advice. They will probably ask what your listening preference is(music or HT), and what you are driving them with. The size of your room. That info would be helpful to answer your questions.
    Again Welcome
    Ben
    Ben
  • okiepolkie
    okiepolkie Posts: 2,258
    edited June 2007
    RC-Entry level speakers. Sound good for the money
    SC-Custom Installation series(available through specialty shops and custom installers). Share many of the same characteristics as the TC series. This series is voice matched to the RTi series, which are good for home theater environments. Sound even better for the money.
    TC: Mid-level in-wall series. Again, comparable to the RTi series.
    LC: Higher end sound, comparable to the LSi's. There is dramatic difference in sound from the other series. Overall, they are much better speakers, and sound good for music and movies.
    Tschüss
    Zach
    F1nut Posts: 51,782
    edited June 2007
    The LCi series are impressive. You'd be hard pressed to tell that they are in-walls. I understand the LCi-RTS are even better.
  • kcrossley
    kcrossley Posts: 12
    edited June 2007
    Are all of the Polk in-wall speakers sold in pairs or individually? The reason I ask is that amazon.com appears to sell some in pairs and some individually. http://www.amazon.com/s/ref=nb_ss_gw/103-1943472-6650266?url=search-alias%3Daps&field-keywords=polk+tC65i&Go.x=0&Go.y=0&Go=Go
  • kcrossley
    kcrossley Posts: 12
    edited June 2007
    Here are some more details about my situation.
    I'm considering some Polk In-Wall speakers for a home theater located in a finished attic that's already pre-wired. The room is approximately 16' wide x 23' long and will have a 96" fixed screen mounted on the 16' wall and a Sanyo PLV-Z5 projector which will mount on the ceiling approximately 15' away.
    Here are the speakers I'm considering:
    Front: Polk RC85i
    Rear: Polk RC80i (ceiling) or Polk RC65i (rear sides)
    Both rear or ceiling speakers will be positioned approximately 16' away from the screen, which is where the seating will be. I'm not sure what to use for the center speaker. My audio installer is recommending that I simply use another RC85i, which would be cost effective, but I see that Polk now makes an LCi-C center speaker.
    Is this speaker setup a good choice for my home theater? If so, which rear and center speakers should I go with?
    Thanks,
    Kelly
  • ben62670
    edited June 2007
    What are you going to power them with? I think most people here would recommend getting floor standing speakers, and maybe a nice center speaker. As for a sub the most popular by far is an SVS. Budget is really a factor here.
    Ben
    Ben
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2007
    Gotta correct Ben on this one. SVS is the most popular sub on this forum (I think, HSU is #2 here). You go to any audio forum - club polk, audio circle, audiogon, etc etc., and it seems every forum has its own favourite brand for speakers, subs, amps, etc.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • ben62670
    edited June 2007
    ViperZ wrote: »
    Yes I stand corrected. The SVS is the most popular sub on this forum. Which says something about the SVS subs. Most of us love Polk speakers yet point to another company for subs. I have had some Polk subs in my vehicles, and they are nice, tight, musical subs.;)
    Ben
  • kcrossley
    kcrossley Posts: 12
    edited June 2007
    What's an SVS?
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2007
    Subwoofer!
    Although Polk is coming out with several different new subs later on this year that might be worth looking at.
  • kcrossley
    kcrossley Posts: 12
    edited June 2007
    Where can you buy one online?
  • amulford
    amulford Posts: 5,020
    edited June 2007
    You can get them off of their website SV Sound subwoofers
