Musical small sub $500 budget
Gaara
Gaara Posts: 2,415
edited July 2007 in Speakers
OK money has been tight recently and I am downgrading my surround amp so I can afford a sub for my PC rig. The speakers are Stone Image Audio Rothschilde A2s and I am looking for a sub to match and play 60hz down. This sub will be used for about 80% music at low levels and 20% movie trailers, tv shows, and games. I need a sub that is:
Less then $500 new or used
Maximum size of 15x15x15
Probably want a sealed sub, never been a fan of ported ones for music
Doesn't need to dig that deep, 25hz is fine for me
Doesn't have to play that loud, my source is less then 1v and I use a passive pre-amp which never gets close to max.
There it is, I am looking for a fast musical sub that doesn't have to play to loud or dig to deep. My main concern is speed and accuracy. So far I have been looking mainly at the AV123 Onix UFW-10, the ACI Force XL, and the Dayton Audio Titanic 10. Any other subs to look at or recommendations would be greatly appreciated.
Thanks.
Jared
Post edited by Gaara on
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    anonymouse wrote: »
    I have the Dayton Mk 2. It sounds sweet and blends well with LSi9's.
    I was going to suggest the same! Buy the kit, put together yourself, and save big. :)
    Ben
  • Gaara
    Gaara Posts: 2,415
    edited June 2007
    So we have two votes for the Dayton. Actually I owned the 10in mk2 and used it with a pair of LSi9s as well, I should have kept it as it did blend quite well.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited June 2007
    I have not heard the smallest sealed SVS sub, but I bet its worth considering. If you can find a used Sunfire True sub, that would be another good option. Very quick and musical, provided you don't push it very loud (it distorts fairly easily.)
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2007
    My vote would go for used Sunfire (jr?) as well... Although my Earthquake SuperNova is small too (15"x15"x15" sealed with 12" driver and 12" passive radiator).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited June 2007
    I've got a Super Junior (Sunfire) and it is very musical...I think it is 9X9X9...Really about 10X10X10 with the drivers sticking out of the cabinet....It pounds, I haven't had any problems with distortion either...I push it pretty hard sometimes....I got mine for $500 shipped...
  • tcrossma
    tcrossma Posts: 1,301
    edited June 2007
    I have a Paradigm Ultracube 10 that is small and quite musical, with plunty of power and low-end for my HT needs. It's basically a 1ft cube. I paid $800 new almost 2 years ago, so i'm sure it could be had in the $500 range now.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • dougy
    dougy Posts: 182
    edited June 2007
    I use two Dayton Titanic III 10"ers in my media room HT. Both have had to have the volume pot repaired under warranty. Other than that, they've been fine. The sound quality is very good for the money. A while back, Parts Express had all the Titanic subs on sale. The 10" kit was just $288! I don't know if more performance can be had for less money in a new sub. They won't win any style points, though.
    THE MAN-CAVE 5.1 CHANNEL A/V RIG
    Sony KDS-60A3000
    a/d/s/ HT-400LCR (3)
    a/d/s/ HT-300 (2)
    Velodyne DLS-4000R (2)
    Pioneer Elite VSX-55TXi
    Pioneer Elite DV-47Ai
    Sony BDP-S300
    Sony SLV-779HF
    DirecTV HD sat. receiver
    MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
    Adcom GFA-5500
    Bose 901 Series VI
    NAD C-165BEE
    Slim Devices Squeezebox Classic
    TEAC CD-RW890
    Technics SL-BD20D w/ Audio-Technica P34
    Akai HX-A3X
  • Gaara
    Gaara Posts: 2,415
    edited June 2007
    So we have 3 votes for the Titanic and 3 for sunfires with 1 for paradigm.
    I did more research and the Onix is out, apperently the UFW-10 has some issues with the amp buzzing and the only fix is to buy a new amp. I looked at the Sunfire Dominators for a little while but they seem to be good for ht but not so good for music according to reports.
    I actually have a Earthquake Supernova MK-IV 12 upstairs which will eventually be replaced. I am not a big fan of it for music, I actually preferred the Titanic which it replaced for music but the Earthquake got a lot louder and extended much deeper.
    Leaning towards the Titanic right now as I can pick one up for less then $300.
  • cstpeter
    cstpeter Posts: 387
    edited June 2007
    Martin Logan Dynamo. Very fast and musical.
    Von Schweikert VR4-jr
    Valve Audio Predator
    Denon DVD-2900
    PS Audio Digital Link III w/Cullen Level IV Mods
    Pro-Ject Xpression w/Blue Point No. 2
    Graham Slee Special Edition 2
    PS Audio UPC-200
  • ohskigod
    ohskigod Posts: 6,502
    edited June 2007
    Dayton seems like a damn good option given your specs, but if a HSU stf2 used rears its head, give it a shot. usually can be had for under 300 and for a ported sub, was surprisingly tight and musical.
    just throwing out options
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • auto_pilot
    auto_pilot Posts: 256
    edited June 2007
    Check out the Outlaw Audio site...I have the LFM 2...and this little sucker can pump...Musically it adds depth to my smaller bookshelf speakers...so it can be unobtrussive to blend in with music...but crank it up a bit, and the bass can be forward, but not droning.
    They also have a new 10 inch sub coming out for $499...I wish I knew, I would have waited.
    These are the reviews for the LFM2:
    http://products.howstuffworks.com/outlaw-audio-lfm-2-subwoofer-review.htm
    http://www.hometheatermag.com/floorloudspeakers/1206totem/
    Cambridge Audio AZUR 640R
    KEF IQ2C Center, Fronts KEF IQ1 , Rears KEF Ci302Q
    Sub Outlaw LFM2
    Panasonic Plasma 1080i (50u)
    Sony DVP-NS70H (DVD)
    Belkin Pure Audio PF31 Line Conditioner
  • Early B.
    Early B. Posts: 7,900
    edited June 2007
    Hsu, man, Hsu!!!
    "God grooves with tubes."
  • avguytx
    avguytx Posts: 1,628
    edited June 2007
    I have a Sunfire D8 that is 9.5" cubed that I am going to be selling soon. It's a little brother to the Super Junior which is a great sub BTW! It's an 8" sub with the high back EMF technology and rated at 1000 watts. It sounds a helluva lot better than the PSB SubSonic 7 15" sub that it replaced at 1/8th of the size!
    I don't want to throw any prices in here because that's not what this thread is about!
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • avguytx
    edited June 2007
    DaveM...tried to send you a PM back but it says your inbox is full.
  • ben62670
    edited June 2007
    Bose Bass module, and be done with it:p :D
    Ben
  • DollarDave
    DollarDave Posts: 2,575
    edited June 2007
    avguytx wrote: »
    Now cleaned up.
  • avguytx
    edited June 2007
    Ben, is that your choice of sub for adding on to your "new" SDA's? ;) :rolleyes: :D
  • Gaara
    Gaara Posts: 2,415
    edited June 2007
    All of the HSU units are to big it seems, the STF2 is 19in high and 18in deep which won't fit where I want it to.
    The outlaw seems like it would work, but it only extends to 28hz which is a little shy of what I was looking for.
    Martin Logan Dynamo...I have heard the other Martin Logan subs like the depth and descents and was very impressed. I'll add this one to the list.
    I will have to look more in depth at the REL units.
    So many choices it is so overwhelming. Especially since I moved the speakers around and now am getting good bass down to 40hz or so after which they drop off drastically.
    Zero,
    Actually I have been meaning to PM you over at audio circle. Expect my impressions later today, in short they are phenomenal. Do you think adding a cheaper sub $500 sub will adversely affect things? Bass is phenomenal with these now that I took your recommendation and moved them closer to the wall.
    Thanks for all the replies everyone.
    Jared
  • haimoc
    haimoc Posts: 1,031
    edited June 2007
    Couple months ago, I bought a Mirage BPS400 ($1200 new, discontinued) for $150.00 from WDC Craigslist. It has 2 12-inch drivers, and it produces very deep and tight bass. I owned Polk and SVS subwoofers, and this Mirage subwoofer is the best in all.
    Pictures can be found here:
    http://cgi.audiogon.com/cgi-bin/auc.pl?homesubw&1172542355
  • Gaara
    Gaara Posts: 2,415
    edited July 2007
    OK I did lots of reading of reviews, different forms, and taken into consideration everything said here...and I wound up going a little over budget.
    I got a Martin Logan Grotto for $600 shipped in a 9/10 condition. I'll be sure to post my thoughts once it arrives and I have it setup.
    Thanks for all the help everyone.
    Jared
