Db212-2 question
Bloodhound50
Bloodhound50 Posts: 23
edited June 2007 in Car Audio & Electronics
can i wire this to a 1 ohm load? and how? they are two 2 ohm svc right? or is that after being wired in parralel?
Post edited by Bloodhound50 on
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2007
    No.
    Its a 2 ohm load.
  • Bloodhound50
    edited June 2007
    i know its a 2 ohm load.... can i change it to 1 ohm was the question.
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited June 2007
    12-2 ?? that's a dual 2 ohm coil is it not? if so, wired in parallel, that's 1 ohm.
    The Artist formerly known as PoweredByDodge
  • MacLeod
    edited June 2007
    Right. Which is why I wrote "NO" in my reply.
    Its a pair of 4 ohms subs wired in parallel and running out to a single terminal. Its a 2 ohm load. The only way to get a 1 ohm load would be to buy a 2nd DB212-2.
  • [Deleted User]
    [Deleted User] Posts: 763
    edited June 2007
    Or replace the subs with DVC's.
  • Bloodhound50
    edited June 2007
    To be honest, I was tired and not thinking or paying attention when I read that. Sorry and thank you for your assistance.
