My Most Recent Acquisition...
Early B.
Early B. Posts: 7,900
I replaced my Behringer A500 amp with an RBH RAM-200 subwoofer amp. Just wanted to try something new and get a real subwoofer amp with crossover and phase features. Still trying to get the "auto-on" to work, though. Not surprisingly, the RBH is a bit cleaner than the Behringer. In fact, it's almost too clean for HT (sub is not used for music). The power output is about the same. I almost have to max out the volume to drive my 15" DIY sub. Here's some pics...
"God grooves with tubes."
Post edited by Early B. on
  • engtaz
    engtaz Posts: 7,671
    edited June 2007
    Keep us updated on your impressions.
    engtaz
  • jm1
    jm1 Posts: 618
    edited June 2007
    Early B. wrote: »
    I am curious; why would this be too clean for HT use?
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • Early B.
    edited June 2007
    jm1 wrote: »
    I said it was "almost" too clean. I have to get accustomed to hearing less boominess. I like it, though, because I can turn it up even higher without distortion.
    Some people, myself included, divide subwoofers into two broad categories -- music and HT. A "musical" sub is very tight, accurate, and fast, and can distinguish between various bass notes. An HT sub is very powerful and impactful, plays loud, and a bit boomier than a musical sub. An HT sub doesn't have to be very accurate or tight because in a movie, you don't want your explosions, for example, to sound "musical." Although it sounds great for movies, I wouldn't consider using my HT sub for music.
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited June 2007
    No reason a musical sub can't be powerful and impactful. I don't like boominess for music or HT.
