Headphones?
jflail2
jflail2 Posts: 2,868
edited June 2007 in The Clubhouse
The better 1/2 just gave me my birthday present, a set of Sennheiser 485's!
I know they're not the nicest cans on the market, but these things have blown me away so far. I had no clue bass could be that....present in a set of headphones. And clean! I'm not good at describing what I hear, but the clarity is just incredible. The highs are crisp, the lows are deep and accurate, with no distortion or muddiness. Talk about renewing a love for classical music in the workplace; these have most definitely done it.
So what nice headphones do you have/recommend? It wouldn't hurt to have another pair at some point for my office, and to leave here at work permanently, etc :)
I'm sure in the grand scheme of things these are just "above average", but they have certainly impressed me.
Post edited by jflail2 on
  • mulveling
    mulveling Posts: 505
    edited June 2007
    What you're hearing in the bass region is a complete lack of room effects...all but the most meticulously designed speaker systems will have significant deviations from a flat bass response due to room acoustics (not to mention the issues with phase, etc with multi-driver systems). Headphones can be a wonderful reference if you don't mind the sound-in-the-head thing. Some people just gotta have a big wall of sound in front of them :)
    When you're ready to step it up, the Sennheiser HD650 at ~ $300 new will get you about as far as you'll need to go in the headphone world, though you can buy some other nice headphones up to $7K (used!). The rest is up to your source and amp - oh yeah, at the HD650 level you'll need a nice dedicated headphone amp, preferrably tube...it also benefits greatly from a nice vinyl source :)
    On the more affordable end of the spectrum, stuff you can buy on impulse - $30 for a set of Koss PortaPros might be worth a try against your 485's. The PortaPro has a sonic signature vaguely similar to the HD650 and the $2.5K Audio-Technica L3000.
    Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
  • mulveling
    edited June 2007
    Another of the things I love about a good set of headphones is that many of the so-called "bad" recordings will sound great again. Especially with hard rock & metal, which are typically written off for recording quality. I sometimes wonder if these complaints are fully valid...this kind of music is naturally busy and at a fairly constant high volume level...the nuances can be hard for a speaker system to completely resolve once you factor in room acoustics, crossover networks, and phase coherence. Something like jazz, with varying levels and much more distinct instrument separation, seems like it would be less apparently affected by these problems. Anyways, I digress :D If you're not allergic to enjoying headphones then they'll give you an excellent alternative to enjoying music.
    Some of headphones I've owned in the $300-$4000 range (many of which are long discontinued)...
    Sony MDR-R10, Sony Qualia 010,
    Audio-Technica L3000, W2002, W11jpn, W10vtg, and W5000.
    Grado HP1000, RS1 (2 pairs, 1 old vintage), RS2, HF1, SR225
    JVC DX1000
    Sennheiser HD650, HD600, HD580
    Ultrasone Edition 9
    AKG K1000
  • danger boy
    danger boy Posts: 15,722
    edited June 2007
    I have a pair of Sennheiser HD-590 headphones.. they sound great.. esp when used with the Outlaw Audio 990 pre amp.. the pre amp has three different headphone processing formats... the best one is DPL headphone.
    PolkFest 2012, who's going>?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2007
    so if I were going to spend $100 tops on a pair of cans, what would you guys suggest?
  • mulveling
    edited June 2007
    Polkmaniac wrote: »
    Unfortnuately I'm not too experienced with headphones under the $200 mark...going from what I've heard, only the PortaPros have impressed me. I love them, and eagerly recommend them to anyone willing to spend 30-40 bucks on headphones. Bought them as a gift for a coworker who's also a musician, now he loves and raves about them too :)
    I use them at work, unamped out of my PC - total system cost $40. My home headphone system costs several thousands ;)
    The Sennheiser HD485 mentioned by the OP is also < $100 and could be a nice choice. There seem to be other good Sennheiser options in that range. Check out the descriptions from headphone.com; they're pretty honest in their evaluations:
    http://www.headphone.com/products/headphones/all-headphones/
    Some people love the Grado headphones, but I'm not a big fan. Their low-end stuff sounds bad to me, and the high end stuff is overpriced IMO. I'd take the PortaPros over any of their headphones under $300, lol.
    The typical recommendation in these situations is to browse the head-fi.org forums, but IMO that's overkill for a $100 budget. The headphone.com recommendations are perfect for someone just starting out.
  • AsSiMiLaTeD
    edited June 2007
    Can you provide an overview of sound characteristics of the Grado and the Portapros?
    I have LSi stuff around the house, and like that more laid back sound.
  • mulveling
    edited June 2007
    Polkmaniac wrote: »
    The PortaPros are def way more LSi-like than Grados (I've owned the LSi7, 9, and 15's). Grados are very forward, bright, lots of energy up top. Kind of a hyped-up sound IMO. Can be a bit harsh & fatiguing. The $30 flat pads really tame the treble down and fill out the bass, but you start to sacrifice resolution on the low-end models (they're a must for the $300+ Grados though).
    Some like the Grado-type sound and call the PortaPro/HD650/L3000 sound too dull & dark, of course this is all personal preference. To my ears, this "dark" sound is just right.
  • ninerbj
    ninerbj Posts: 870
    edited June 2007
    For under a hundred clams, these little gems are hard to beat.
    I use these quite often and for the money, couldn't be happier.
    http://www.headphone.com/products/headphones/all-headphones/grado-sr-60.php
    "she had the body of Venus, with arms."
  • Sami
    Sami Posts: 4,634
    edited June 2007
    Polkmaniac wrote: »
    You might want to up the pricepoint to $150. I got my HD-580's for $130 from Amazon like quite a few here so wait for a good deal if possible. Too bad you didn't mention any interest to headphones, you could have tested the 580's when you picked up the LSi's. They are driven by Yamaha receiver hooked up digitally to a computer. For iPod users I don't recommend them, it lacks the power to drive these adequately.
  • mulveling
    edited June 2007
    Sami wrote: »
    Yep, the HD580 are an excellent set of cans for the price. Definitely worthy of consideration if you can swing a few extra bucks. Sound is virtually identical to the more expensive HD600. Compared to the HD650, both are just a touch bright (still nowhere near Grado levels) and grainy, with slightly cold & recessed mids. However in most aspects they're very similar to the HD650 and the HD650 starts at $300...
    The HD580 and HD650 truly set the standard at their respective price points.
    Anyone who turns out to be a Grado-with bowl pads-lover can safetly ignore most of my recs :D The only Grado I've really loved is the HP1000 (with flat pads) which is long discontinued and significantly different in sonics from the current line. Different designer (Joe vs. John Grado), different philosophy, different sonics.
  • audiobliss
    audiobliss Posts: 12,518
    edited June 2007
    I really enjoy listening to my Sennheiser HD-590.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
    billbillw Posts: 7,541
    edited June 2007
    I'll give an additional nod to the Senn 580s. I've had a pair for a few months and am loving them. They sound very good even just using the output on my 2-ch pre and/or my bedroom 2-ch receiver. My main HT receiver is a little weak in the HP circuit, but the others are more than adequate.
    Oh yeah, its hard to beat the comfort of the Senns too.
    Amazon's price is by far the best on these and if you can swing one of their $30 off promotions (by signing up for a credit card), they are the worlds best $100 cans, bar none. I signed up for the credit card, got the $30 back, made one payment of $99.99 and then canceled the card. Thanks Amazon!
