Is anyone using SUPERANTISPYWARE?
candyliquor35m
http://www.superantispyware.com/index.html
No affil.
A friend of mine used it and was happy with the results but I wanted a few more opinions before trying it.
No affil.
Post edited by candyliquor35m on
I use Spybot Search & Destroy and Windoze Defender and have had no problems. If you are going to try this SUPERAntiSpyware, make sure you set a system restore point before you install it, in case you don't want it and the uninstall doesn't work.
AdAware - www.lavasoft.com
Spybot S&D - http://www.safer-networking.org/
AVG Anti-Spyware - http://free.grisoft.com/doc/avg-anti-spyware-free/lng/us/tpl/v5
I'd steer clear of anything else. For really tricky problems I pull out Hijack-This, but you need to know what you're doing with that program.Ludicrous gibs! -
