Ceiling speakers
MuchoGrande
MuchoGrande Posts: 10
edited June 2007 in Speakers
i have blown insulation in my attic ... does anyone know what comes with a set of ceiling speakers ... not sure which set i want yet, i have monitor 70's for the front and a CS2 center is on the way.
my concern is will any of the insulation get into the back of the cone? should I just frame in the rafters and screw down MDF on top to "seal" the speakers and protect it from the blown insulation?
Post edited by MuchoGrande on
  • Music Joe
    Music Joe Posts: 459
    edited June 2007
    If you don't want an enclosed type speaker or have no desire to box it in you can push the 'blown in' well away from the speaker backs and lay in a panel of high R value insulation batt with a hole cut out for the driver back.
    Most ceiling speakers I've seen have vented dust caps and the spider keeps contamination out of the magnetic gap.
    I have seen a rear vented magnet but it came with tuned molded abs enclosures.
