Buying used.
Belcon
Belcon Posts: 25
edited June 2007 in Electronics
I see more and more people buying used equipment. I know there is a value to it and your money has more purchasing "power",but aren't you tempting the fates and hoping for good luck?
No warranties or guarantees, but you will save alot of money. Your credit card company can't offer you protection with charge backs.
My question is, how do you ensure that you are getting exactly what you are paying for and the transaction goes smoothly.
The reason I am asking this is...I want to buy equipment that will power a set of LSI9's, but don't know if I shoould buy a used pre amp and amp or do I play it safe and buy an integrated like a NAD c325 BEE?
It's got me swinging...:eek:
Post edited by Belcon on
  • venomclan
    venomclan Posts: 2,467
    edited June 2007
    Welcome Bel,
    There are always risks in buying used, it is best to test the track record of an item to see if it is worth it. Most people here tend to take great care of their stuff, and that helps when it is a hobby of interest, rather than just an equipment fipper. NAD is usually good stuff, if the owner took care of it, go for it.
    V
  • Belcon
    Belcon Posts: 25
    edited June 2007
    Sorry. I meant by used amp and pre amp or buy a new NAD integrated. They may be close in price, but I guess I want to see what others have experienced so I can use it before I leap.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2007
    I love buying used. You typically get items for 40-50% of their MSRP, so as long as half of them work out well, you're in the black.
    Honestly, I buy all of my equipment used these days. If you buy from a reputable seller off Agon or here, you'll be fine. If you buy from ebay, you might have more mixed results, but I've got 30+ audio buys on ebay and only one mildly bad experience there.
    Most sellers will offer some type of refund, especially if it's not working as it should. Also, used audio isn't too hard to fix in many cases, and manufacturers will often fix products for reasonable costs should a problem arise.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • bikerboy
    bikerboy Posts: 1,235
    edited June 2007
    Hi,
    I have been buying used for the past 5 years. I have been lucky or bought from people who didnt burn me. I look at it this way, if I can save 50% on a purchase by buying used that pays for a lot more or better gear. If one thing goes wrong I would still have saved money in the long run. With all the help this forum gives I find it a lot easier to buy used. And even better if you can buy from one of our members. A big plus! Just do some research and dont buy from slezbay and you should be ok. Good luck.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
    heiney9 Posts: 25,509
    edited June 2007
    It does take a little time and experience to spot potential problems sellers on E-bay. There is some risk involved, but IMO the reward is worth a little bit of risk. Ask many questions and if it seems to good to be true in many cases it is. If something doesn't sound right, feel right or look right walk away. Or if the seller isnt that interested in communicating with you walk away. In the past I was very interested in a piece or two but the sellers had poor communication and just didn't want to be bothered with my inquries so I moved on.
    The only other thing with buying used is you have to have some patience and really know what you want and it helps a lot to know about said item ahead of time. Don't always rely on the seller to know what he or she is selling. They are selling it, so it's the best one avail, best sounding, best looking, nothing else like it, one of kind, etc, etc, etc.
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    Almost all my audio gear is used. Best value and better equipment can be had for less money.
    engtaz
  • JimBRICK
    JimBRICK Posts: 1,543
    edited June 2007
    I've learned lately that I only buy off on the FM on here
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • MSALLA
    MSALLA Posts: 1,602
    edited June 2007
    My gear is also mostly used. I have not been burnt (Knock on wood) by any sellers and everything has been in as new condition. E-bay tends to have the highest risk but you can spot most scams by reading carefully. I also like to ask members on here about products I am looking at to make sure it is relly what I'm looking for. The people selling the higher end gear are people who could afford to buy this stuff new and they tend to take care of thier equipment.
    P.S. welcome to the fourm.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • Belcon
    Belcon Posts: 25
    edited June 2007
    So the theme I am seeing is based on the law of averages, things will work out in my favor and for the most part, stay away from ebay.
    All in all, everyone seems to recommend buying used over buying brand new because you get more for your money even without warranties.
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2007
    The first thing I ever bought used was my Definitive BP10Bs from Sid on this forum. I was very happy with the purchase since he took great care of the speakers.
    If you are going to buy used, make sure you can check out the item before you buy it. I took a 12 hour trip to NC from NY in order to check out the speakers.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Belcon
    Belcon Posts: 25
    edited June 2007
    With kids and a busy life, physically checking things out is difficult. I live in "upstate" ny and to be honest, I think the fan base of decent audio equipment is weak at best.
    I can't begin to tell you how many people I know that own HTiB over piecing together a decent system that can cost less than the HTiB.
  • Serendipity
    edited June 2007
    Belcon wrote: »
    Where in upstate NY?
  • Belcon
    Belcon Posts: 25
    edited June 2007
    I live in East Greenbush across the river from the capital.
  • Serendipity
    edited June 2007
    There are a few shops up in Albany. Also, if you ever are in NYC, I'd recommend a visit to Audio Breakthroughs and Park Avenue Audio.
    I'm lucky that I live 20min. away from Manhattan and there are HiFi shops everywhere.
  • Belcon
    Belcon Posts: 25
    edited June 2007
    They are slowly diminishing. I got lucky and landed a pair of in box LSI 9's Ebony for $400 and change because Tweeter was going out of business. I can't complain for what I paid, but I don't have the right equipment to power them. Or should I say I am just putting them into a 2 chnl system and the rec'r I have doesn't do them justice.
  • George Grand
    George Grand Posts: 12,256
    edited June 2007
    You hang around here for a few more posts. Get yourself eligible to buy and sell on the Polk Audio Forum Flea Market. You'll eventually find exactly the equipment you want, probably at a great price, and you'll feel a lot more comfortable about who you're mailing your hard earned dollars to. It's that simple.
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2007
    Welcome Belcon.
    Nine times out of ten, you will never have to have something repaired within the warranty! Are there lemons? Sure, but most times you get other gear because of changes in technology, not because the piece of gear broke.
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited June 2007
    I have only bought audio items off e-bay twice, and got burnt both times. I have also bought few items here, and from the AVS forum, and everything went flawlessly, except once. That was an item claimed as new, but it wasn't. I still sold it for the same price I purchased it for, no loss.
    So I would say you are OK if you buy here, but avoid e-bay.
    I must admit though, I prefer to buy everything new, as I am very picky about the items in my rack, they must be mint.
  • madmax
    madmax Posts: 12,434
    edited June 2007
    The flea market here is fairly safe. AudioGon seems good too. 200+ ebay transactions have treated me well.
    Its a nightmare in safety though. You have to do all the things you know not to do. For example, you send payment which is non-protected to someone you have never heard of before and hope they send you the item they say they have to sell. Then you just wait two weeks to see if they actually had the item to start with, if it worked, if it was damaged (either before or during shipment)... Horible.
    The good side: 99.9% of the people out there WANT to treat you fairly and are being at least 75% truthful. Numbers I've pulled out from nowhere but you get my drift.
    So, what happens that one time you send someone a few $K's and they screw you? Well, hopefully you have done it enough to be able to mark it off as education.
    madmax
    Vinyl, the final frontier...
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    I don't mind amp,AVR, and others but Ebay is a risk on shipping speakers. Local pick up not a problem.
    engtaz
  • John in MA
    John in MA Posts: 1,010
    edited June 2007
    I've never bought a new audio component, unless you count a switchbox from Radio Shack when I was 14.
