Thanks Vr3MxStyler2k3!
Serendipity
Serendipity Posts: 6,975
edited June 2007 in 2 Channel Audio
I've been confused by my lack of true bass (below 55Hz) and too much bass in the 55Hz-70Hz range from my DefTech BP10B's. In addition, I've been confused by the lack of ANY output from my subwoofer. So I remembered a while back when Sid demoed his system to me and said that lowering the bass -4db on the preamp cleared up the "congested" sound from the Definitives.
So... I started with the tone controls flat at 0db, then changed my fronts from "Large" to "Small" with a crossover at 80Hz. As a result, I was able to lower the bass from 55Hz-70Hz by turning the sub down a few notches, until it was almost off. Now I have a nearly flat frequency response down to 18Hz. And I'm really glad that I got rid of the boomy bass from the Definitives!
Thanks Sid for all your great advice!
The BP10Bs would not sound so good if it were not for your help!
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
