Speaker matching
jerry22m
jerry22m Posts: 14
edited June 2007 in Speakers
How important is it to match fronts/center to back/surround speakers. Thanks Jerry
Post edited by jerry22m on
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    I think it is pretty important if you like 5 or 7 channel stereo.
    engtaz
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited June 2007
    I think it is imperative that the front end matches, but I think that many of us do not have matching rears.
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • Gaara
    Gaara Posts: 2,415
    edited June 2007
    That depends on a lot, like how much they will be used, what your fronts are, what the rest of your equipment is etc.
    For example if you had a HTIB that was used more for music then movies then not very. While if you had $100,000 HT system with hand picked synergistic components which will only be used for movies and multi-channel music...very.
    Personally I tried using different brand rears and surrounds and didn't like it. The rear soundstage was there but it didn't really blend together, like I could hear the fronts then I could hear the surrounds and the rears.
    Going with the same brand things were seamless, one big soundstage as opposed to 3 smaller ones. Effects sounded much more realistic and it was much more enveloping. Definitely a big step up.
    All depends on your system and your needs though.
  • jerry22m
    jerry22m Posts: 14
    edited June 2007
    Just purchased a pair of Rti10s and Csi5 that should arrive tomorrow or tuesday they will be powered by a Pioneer Elite VSX-84TXSi, was wondering if Rti4 was necessary or if existing Klipsch RB5 would work well. Useage will be 60/40 movie music. Thanks Jerry
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited June 2007
    I think it's fairly important. When that car races from the front of the living room to the rear - or vice versa- you want it to sound like the same car from speaker to speaker.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Midnite Mick
    edited June 2007
    It would also depend on how similar/dissimilar they are as to how noticeable it would be. However, the RTi4's are very inexpensive so you could easily sell your Klipsch's and get the 4's if it's something that you notice and/or bothers you.
    Mike
    Consonance cd120T
    Usher CP 6311
  • venomclan
    venomclan Posts: 2,467
    edited June 2007
    Gaara wrote: »
    LOL, Hey Jared, Diden't we just answer this question on AVS?
    V
