Additional Sub On the way
Sherardp
Ok guys, I just ordered another PB12 PLus/2 to accompany the first one. I also ordered the Velodyne SMS-1. Any tips or suggestions when setting up the dual sub configuration with the SMS-1?
Post edited by Sherardp on
I hope your back is in good shape. You may need to move things around a few times. If you don't have it already, I would download Room EQ Wizard and pick up a SPL meter."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I have my two set with opposite phase settings. After much trial and error I found that to work best for my room. I have the SMS-1 also so I could see the response.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Two of mine are set to 0 and one is set to 15. So as Wingnut mentioned, it can take a lot of trial and error."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Roger that, I will try various settings and see what I get once I get the SMS integrated in my setup. I'm thinking two PB12 Plus 2 subs should put out enough bass to bring the whole house down. My current sub hits pretty deep, I just felt it was lonely and wanted some company.Shoot the jumper.....................BALLIN.............!!!!!
