Dumb Question About LSi's
phuz
phuz Posts: 2,372
edited September 2002 in Speakers
Do the dual binding posts require bi-wiring? Or can regular wiring work as well?
Just exactly how are those posts hooked up to the crossovers?
Thx :)
Post edited by phuz on
    F1nut Posts: 52,164
    phuz,
    Regular wiring will work perfectly. Sorry, I can't answer the second question.
  • TroyD
    TroyD Posts: 13,124
    Phuz,
    Basically in a 2 way crossover one set of binding posts will provide power to the upper frequency driver and one set will power the lower driver(s). If you choose to biamp or biwire you would remove the jumper and run wire to each set of binding posts. If you choose NOT to biwire/biamp, run wire to one set of posts with the jumper in place. The jumper passes the juice to the other set of posts.
    BDT
  • phuz
    phuz Posts: 2,372
    Ahh I didn't know about the jumper. Thanks guys.
    I have bi-wire, but it's not currently setup for bi-wire (one set up plugs with both wires attached).
    Thanks again. :)
