High quality speaker switch
haimoc
haimoc Posts: 1,031
edited June 2007 in 2 Channel Audio
I have a question that hopefully someone that has experience can help me with.
Pre-Processor : Arcam AVP700
HT Amp: Rotel 1075 5-Channel Amp
Stereo Amp: Dodd Tube Amp (From Russman.. :cool: )
If I want Rotel to handle HT job, and Dodd Tube Amp for stereo, how do I set them up with 2 front speakers? Should I look for a speaker switch or selector? Any idea or recommendation?
I rarely use HT, but it is hard to think about getting rid of them..
Thanks.
Post edited by haimoc on
  • Early B.
    Early B. Posts: 7,900
    edited June 2007
    Do you use a pre for your 2-channel system or do you use the Arcam?
    "God grooves with tubes."
  • haimoc
    haimoc Posts: 1,031
    edited June 2007
    I use Arcam AVP700 as a preamp. The point is I don't want the tube amp to handle the front speakers in HT mode unless I have to..
  • Yashu
    Yashu Posts: 772
    edited June 2007
    Adcom, Bryston
    These folks make fine speaker selectors.
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    The adcom switch works for having one source, and multiple speakers. It is an ohm compensating switch that can not be used to switch sources.
    Ben
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited June 2007
    I have thought of this as well because I will be in the same boat soon. This was what I thought I was going to do but was going to ask about it as well...anyway here goes.
    Would it be acceptable to use 1 set of binding posts on the speakers for the HT amp and use the other set of binding posts for the 2 channel amp? Keeping the jumpers on the posts of course.
    Thanks,
    Mike
    edit after reading a little better: sorry not the same situation as I would have separate preamps for HT and 2 channel as well
    Haimoc I cannot think of a way around having the pre accessable so that you can change RCA's
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
