Sub Grill
Quick question, since I didn't find it in the forums from my search. My Sub (psw12) has a removable grill. If I take it off during movies, does the affect bass, in anyone's experience. For bass heavy movies, it literally shakes some of the pegs out of their holes(the grill is cracked, which may be why) Just didn't know if it would afect my sound quality otherwise. For none super shaker movies, it doesn't go loose.
Post edited by skrewloose on
  • jwhitakr
    jwhitakr Posts: 568
    edited June 2007
    Removing the grill on your sub will have no noticeable impact on the sound quality or on the output of your sub.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited June 2007
    If it's cracked, I would just take it off and store it man...Easier than dealing with removing it every time you watch a "super shaker movie"......I know it may not be a big deal to remove it every time, but the annoyance factor would drive me crazy...I also tend to prefer the look of subs without the grill on..
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2007
    Leaving it off shouldn't affect the sound quality.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
