Alright I need to know what Amp could handle these...??
T_Unit616
Alright, I posted earlier. Twice. This should be my last one. But ya I just bought 2 10" Pioneer subs. Here are their stats:
120 Watts RMS Power
600 Watts Maximum Power
Frequency Response: 20Hz - 4,5kHz
90dB Sensitivity
4 Ohms Impedance
4-Layer, Long Voice Coil
Projected Pole Yoke with Vented Pole
Push Terminals
Both are the exact same. And I might also put in my Rockford Fosgate. That is 100 watts/200 peak watts, 92dB, 4 Ohm, 28-2,000Hz. So what is the amount of power I will need in my amplifier?
120 Watts RMS Power
90dB Sensitivity
4 Ohms Impedance
Push Terminals
Post edited by T_Unit616 on
Alright guys, I just bought a 1600 wat amplifer 4 cahnnel. here are the stats. It should take on my 2 600 watt subs right (MAYBE a 100 watt Rockfored Fosgate..?
400 Watts x 4 Output
800 Watts x 2 Bridged Output ( 400W x 2 + 800W x 1 )
Dual Variable Hi/Lo Electronic Crossover Network
Variable Input Level (Gain) Control
Dual Variable Bass Boost
Dual MOSFET PWM Power Supplies
Thermal / Overload / Short Circuit Protection
Power & Protection LED Indicators
High & Low Level Inputs
Gold Plated RCA Inputs
Remote Bass Boost
Remote Turn On/Off
Soft Turn-On Circuit
Protection Circuitry
High Level MOLEX Inputs
Anti-Thump Turn-On
Tri-Mode Configurable
S/N Ratio: 95dB
T.H.D: < 0.04%
Frequency Response: 15Hz- 30kHz
Dimensions: 11.34''W x 2.24''H x 15''L -
That'll be around 100 - 125 x 4 if you're lucky.
Anyway... you grabbed the wrong amp. You could run 4 of the pioneer subs off of that, or bridge it and run 2 better subwoofers like a polk db junior or recent momo models. (assuming you get around 350 to 400 x 2 bridged @ 4 ohms.The Artist formerly known as PoweredByDodge -
PoweredByDodge wrote: »That'll be around 100 - 125 x 4 if you're lucky.
Wait, I might only run two. The 2 10" 600 watt pioneers, and maybe the 12" 100 watt Rockford Fosgate.
