Best way to listen to music on HT
arakhavan
arakhavan Posts: 8
edited June 2007 in 2 Channel Audio
Hey guys,
I Have a Harmon Kardon 245 receiver with a 5.1 setup as follows:
front-Polk r50
rear-Polk FXi3
sub-Velodyne DPS12
What are your preferences for listening to music?
stereo, 5 channel stereo, dolby music other...?
Post edited by arakhavan on
  • MillerLiteScott
    MillerLiteScott Posts: 2,561
    edited June 2007
    2 Channel, no sub, and a cold beer.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • engtaz
    engtaz Posts: 7,664
    edited June 2007
    2 channel, direct mode with sub adjust for music{turned down a little} (R50's need help with lower end) and a nice cool drink.
    engtaz
  • W WALDECKER
    W WALDECKER Posts: 900
    edited June 2007
    Two channel with Tubes somewhere in the system.
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • Ern Dog
    Ern Dog Posts: 2,237
    edited June 2007
    I also have an HK AVR and liked the stereo mode with the DSP turned off, with a sub to help with the low end. I'm a bass fiend and can't live w/out a sub. I have it dialed in so that it is seamlessly integrated into the mix.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2007
    The HK hooked up analog into the 6/8 Direct inputs has a larger more detailed soundstage than the digital connection. Salt with sub to taste, but you'll need some sort of BM on your player.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • arakhavan
    arakhavan Posts: 8
    edited June 2007
    what cd player do you recommend with 6/8 outputs?
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2007
    I go with Stereo, front speakers set to large AND sub on. Digital input is what I use to get bass management, I don't think many CD players offer much in the way of BM.
    I, like Ern, like a little bass in my music. If I want the best possible sound, I go to my 2-channel setup. If I want to bump, I got to the HT and make it loud.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Lowell_M
    Lowell_M Posts: 1,660
    edited June 2007
    My setup is slightly different now...but the way I used to have mine set up is as follows...
    My CDP has two digital outputs, optical and coax. I used the optical output for the DVD input in the HK and the coax for the CD input. The DVD input was always set to Dolby digital surround for movies and the CD input was always set to 2-channel stereo.
    The problem with the H/K receiver is you can't change crossover settings between the different inputs. so I optimized the sub for my HT tastes and just put up with it in 2-channel. Now I have an Entech Numbercruncher DAC that I feed into the L and R channels in the 6-channel direct mode so that I can play pure 2-channel with no sub. You can do the same if you have a decent DAC in your CDP as well.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • Skynut
    Skynut Posts: 2,967
    edited June 2007
    I go through the settings on my Sunfire and see which one I think sounds the best.
    Then I turn it up and walk away to do something productive.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2007
    I'd recommend 2 channel stereo without a sub.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
