I need some Polk car equipment
m00npie
Hello,
I recently had a Kicker system installed in my Jetta from a shop close to work. They were not a Polk dealer so I went with a Kicker system. Im pretty happy with the sound but now Im ready to experiment with another sub to replace the Comp VR10 which is currently driven by a Kicker ZX400.1
I recently bought a Kicker amp (ZX750.1) off of 1996blackmax figuring I would need more power to upgrade to a 12 sub. I would like to try a single 12 from Polk but I have a few questions surrounding this purchase
1.) What is the difference between MM2124DVC and the MM2124, and is there a sound difference between the two?
2.) Polk does not sell sub boxes and I have no interest in building my own so is there a particular brand that is suitable for a single 12?
3.) Since I listen to 98% Rock\Metal, would the MM2124 be better than the CompVR from Kicker or should I consider the SR124. I dont think the amp I bought would be enough to drive the SR so that may be out of the question.
Any help would be greatly appreciated.
Post edited by m00npie on
1) there's no sq difference between a single and double coil sub, it's all dependant on how you want to wire it... for a single sub, go with a 4ohm+4ohm DVC sub so you can wire it to a 2 ohm load.
2) there are prefab boxes in any BB/CC, but they're relatively crappy... reconsider building your own, or paying a friend to do so, it's not difficult and the results are great. there are companies that make good prefab boxes, but i can't remember any of them... any audio shop can also make a box to your specifications, as well
3) i don't know that amp, and my connection is pretty much broken right now, so i'm not going to the site at the moment, but the momo should be better than the comp (don't hold me to that, it's been a while since i've heard a compvr), and an sr will sound very tight, perfect for fast double kicks, but only if it's got enough juice... if you're willing to pay for it, i'd say go for the SR, but the momo will also yield excellent results.It's not good, very fundamentally simply not good. - geolemon
Polk sells a powerhouse sub-in-a-box. The DB212-2 is flat out awesome!
http://www.polkaudio.com/caraudio/products/db212/
It would also be a perfect fit for that 750 watt Kicker.polkaudio sound quality competitor since 2005
Thanks Mac,
I'm going to have to get my tape measure out. I'm not sure if that box will fit in the back of my Jetta. Would I need 2 amps to drive both of those or just one?
Going from a single 10'' to dual 12'' does sound exciting. I'll have to tape my fuel door shut since occasionally, the single ten will pop it open.
