New here, need a little advice
Bigike40
Bigike40 Posts: 4
edited June 2007 in Speakers
Hi,
I've got a set of LSi15's paired with a Yamaha rx-v3300 rated at 130 wpc. I've also got an older Polk center and rears along with sub. I've been considering upgrading the center to LSic but am concerned a little as I've never been that happy with the 15's. I'm thinking it may be a power issue with the yamaha driving the 4ohm speakers. They've just never put out like I feel they should.
I've had Carver amps/preamps in the past and always liked their power.
My questions are will I be disappointed in the LSic given the fact that it will be hooked to the yamaha? Also, should I consider buying an external amp to power the speakers? I've heard a lot of good things about the Outlaw monos but will they make that big of a difference?
Thanks for all help.
Post edited by Bigike40 on
  • Schwingding
    Schwingding Posts: 363
    edited June 2007
    IMO, you should expect more of the same from the LSiC if you are powering it similarly.
    Yes, external amps _can_l make a large difference if you choose them wisely. I have been very happy with the Outlaw 2200 monos powering my speakers. At one time I had all 5 channels powered by 2200 monoblocks. More recently I have replaced the fronts with tube amps, but the 2200s will be a big step in the right direction from where you are now.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2007
    Welcome BigIke!
    Yes as you noted, you are having a power issue. You should definately look into getting 3 Outlaw Mono's for your LSI's. If you know you are going to get LSI's for the rears as well, then bite the bullet now & get a 5 channel Outlaw & be done with it.
    I used a Outlaw mono for my center channel & it made a big difference. I now have all my speakers amped.
    So get some more power & start enjoying what your speakers can really do!
  • steveinaz
    steveinaz Posts: 19,538
    edited June 2007
    Agree with Schwingy and Cfrizz. Get some serious power and watch those Lsi's bloom baby.
  • george daniel
    george daniel Posts: 12,096
    edited June 2007
    Get an amp with good current and power,,15's are placement finicky,,I have found that if you power them with a good quality amp and tweak the placement,the results will be surprising. Good luck,and enjoy. :)
  • Bigike40
    Bigike40 Posts: 4
    edited June 2007
    Thanks guys.
    I'm seriously leaning towards trying the Outlaw mono's. Can any of you recommend anything else, maybe 5 channel, that would be between $1k-2k?
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    http://www.outlawaudio.com/products/index.html
    Don't forget to check out B Stock. A small scratch can save over $150
    Welcome to CP
    Ben
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2007
    How about something from Parasound? Their amps sound quite good and would be a good match with the LSis.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • cfrizz
    edited June 2007
    Also Rotel, & Sunfire make great amps. Check out Audiogon, you will get more bang for the buck that way.
  • W WALDECKER
    W WALDECKER Posts: 900
    edited June 2007
    The Lsi15's are good with high power/ current power amplifiers, on a darker note,i had them paired with a Rotel RB1080 and it was a pretty disapointing experience for me personaly i cant recomend the Lsi /Rotel amp combination and if i were you i would try to avoid it :eek: thanks....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • cfrizz
    edited June 2007
    What didn't you like about the combination? Just telling him not to get a Rotel isn't very helpful since lots of others have run the 2 together & love the results.
  • cmy330go
    cmy330go Posts: 2,341
    edited June 2007
    I think you are having more of a placement issue rather than a power issue. The 3300 is no joke, being it's essentially a slightly toned down RX-Z1.
    True, more power can't hurt and will improve things, but I would play with placement first.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Willow
    Willow Posts: 11,064
    edited June 2007
    cfrizz wrote: »
    I used a Outlaw mono for my center channel & it made a big difference. I now have all my speakers amped.QUOTE]
    Hmm I wonder where that mono is now ? ;) funny I'm using one on my centre !
    Listen to what people say here, you need the extra power. I didn't think it would be such a difference, Boy was I ever blown away!
  • Shannon W.
    Shannon W. Posts: 568
    edited June 2007
    I run a Singnature CINEMA GRAND 7 on my LSi. So far it sounds GREAT!!!!!!
    Shannon
    50" Samsung Plasma
    Sony STR-DA4ES "use as Pre/amp"
    Pioneer Elite DV-45A DVD Player
    DLO HomeDock Deluxe iPod docking station
    Directv HR20 Sat. Receiver in black
    Sunfire Cinema Grand 7 Signature Amp
    Monster Cable AVS2000
    Monster Cable HTPS 5100 MKII
    Polk LSi 9's Front R/L
    Polk LSiC Center
    Polk LSiFX R/L Surround
    Polk LSi 7's Rear R/L
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
    Click Here To View my Rig
  • cfrizz
    edited June 2007
    :D:D:D:D:D Hmmm very good question, I wonder where it went off too?:D
    Willow wrote: »
  • Bigike40
    Bigike40 Posts: 4
    edited June 2007
    Thanks for all the advice. I appreciate everyone jumping in and giving me some ideas. Now, I've just got to dust off the checkbook.
  • Willow
    edited June 2007
    cfrizz wrote: »
    it doesn't by any chance look like the one in my set up ? ;)
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2007
    Look for multichannel amps on www.audiogon.com. There seem to be several in your price range that would power those speakers well.
    Parasound makes some great valued multichannels, so you might want to start there. Find something that does around 200wpc into 4 ohms with high current (20+ amperes peak to peak). HCA-1205, HCA-1206, A52, etc. I think would all be good choices.
    BTW, where are you located?
    Good luck! B&K is also a favorite of mine, but I think I might go Parasound if I were you for more value.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Bigike40
    Bigike40 Posts: 4
    edited June 2007
    Thanks Andy. I'm in Jupiter, Florida. I guess I need to update my profile.
