Getting Loged Out
Pablo
Pablo Posts: 723
edited June 2007 in The Clubhouse
Does anyone else here get logged out before they are done typing there post? If I spend to much time typing (a few minutes), when I hit post, it says I can't because I'm not logged in. Is there a setting I'm missing?
Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
Post edited by Pablo on
  • bobman1235
    bobman1235 Posts: 10,822
    edited June 2007
    Sounds like a browser problem to me. Your cookies are getting cleared.
    I can't tell you the last time I logged into CP. Both computers I use are always logged in.
  • Gaara
    Gaara Posts: 2,415
    edited June 2007
    The same thing happens to me, it seems if I don't click on something for more then ten minutes or so I get logged out automatically.
    Before I post I copy the text now to make sure I don't lose it. Recently I have been opening a new window and clicking on new posts just to make sure it still registers me as being logged in.
    I use firefox.
  • Mike682
    Mike682 Posts: 2,074
    edited June 2007
    same here
    If I get logged off after typing a message and trying to post it(the screen to log in comes up after I hit the post message button), I just sign back in and the message gets posted.
    I use both IE and firefox
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • Fireman32
    Fireman32 Posts: 4,845
    edited June 2007
    Make sure that you have remember me checked or it will log you out after a certian time of inactivity. I guess writing a post doesn't count.
  • neomagus00
    neomagus00 Posts: 3,899
    edited June 2007
    hmm... if fireman's suggestion doesn't work for those with the problem, i'd be interested to know what systems are experiencing it (OS and browser type)...
  • duksbak
    duksbak Posts: 134
    edited June 2007
    Easy fix.
    Short posts or type faster! :p
    Television: Mitsubishi WD-57732
    Front R/L: Polkaudio RTiA7
    Center: Polkaudio CSiA4
    Rear R/L: Polkaudio FXiA4
    Subwoofer: Polkaudio DSW600
    A/V Reciever: Denon 2808
    DVD/SACD: Sony Playstation 3
  • michael_w
    michael_w Posts: 2,813
    edited June 2007
    Never had this problem with either firefox or IE, but then again I frequent the forum enough to justify using the remember me feature. I don't like using it very often for security but then again it's a forum so there isn't really much to lose.
  • jflail2
    jflail2 Posts: 2,868
    edited June 2007
    In the meantime, type your long posts in word and then ctrl+c ctrl+v over.
    I do that with all of my long work emails so I don't accidentally hit send on an incomplete email...
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2007
    I get that too. Happens on IE6 if you leave the browser window open for 10 minutes or so.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • George Grand
    George Grand Posts: 12,258
    edited June 2007
    Do like Fireman said, it works. The "remember me" box next to where you enter your log-in name. Check the box before you log-in.
  • Serendipity
    edited June 2007
    I do that! And it still doesn't work!
  • scottvamp
    scottvamp Posts: 3,277
    edited June 2007
    appadv wrote: »
    Yep, started awhile back. I have to constantly log in. I use to never have a problem.
  • Serendipity
    edited June 2007
    I noticed that checking the box or leaving it blank does not make a difference.
  • Pablo
    Pablo Posts: 723
    edited June 2007
    At least it gives me a message. I then just right click and copy what I typed and then log in and paste. I just didn't know if it was just me.
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    Csi-40 Center
    PSW350 Sub
    Denon DVD-2910
  • George Grand
    edited June 2007
    appadv wrote: »
    Well that means you're REALLY **** and I apologize. PM Matt Polk and tell him you're not parting with any more cash for Polk stuff till he gets this **** squared away. THAT ought to do it.
    treitz3 Posts: 19,150
    edited June 2007
    Simple fix. Log back in and continue, I have never lost what I was typing.
    Hit submit when done. Done deal.
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited June 2007
    Depending on your browser security settings, you may need to add www.polkaudio.com to the 'trusted sites' list.
    In IE 7 - Tools, Internet Options, Security, Trusted Sites, Sites
  • Serendipity
    edited June 2007
    Just added on my IE6.
    Will see if it works.
  • Serendipity
    edited June 2007
    The add to Trusted Sites did not work.
    Am I doing this correctly? See the attached picture. Thanks!
  • RuSsMaN
    edited June 2007
    http://www.polkaudio.com
    Type that exactly, and remove the 'https', the Polk site is not a secure server.
    (and you still need to check the 'remember me' box when loggin in)
  • Serendipity
    edited June 2007
    RuSsMaN wrote: »
    When I type http://www.polkaudio.com, an error message pops up stating that only secure servers can be added or something like that...
  • RuSsMaN
    edited June 2007
    Look at your jpg, uncheck the checkbox to require https.
  • Serendipity
    edited June 2007
    RuSsMaN wrote: »
    Thanks. I hope it works now.
  • Serendipity
    edited June 2007
    Still getting logged out. And I made sure that I have the "remember me" box checked every time I log in.
    edited June 2007
    Have you tried logging back in and continuing?
  • Serendipity
    edited June 2007
    treitz3 wrote: »
    Yes. That works. I just still keep getting logged out though.
    edited June 2007
    Same **** here, but hitting two extra buttons after a long post ain't enough for me to complain about. (I have user name and password saved, so it takes about 2 seconds).
  • Serendipity
    edited June 2007
    treitz3 wrote: »
    My password is very long. But I'm not complaining about it - I just want to figure out why this happens in certain browsers/computers/etc.
    If there is a definitive solution I would like to know about it.
    Thanks!
    edited June 2007
    I have no idea, I'm not computer savvy. BTW, I wasn't saying that you were complaining, or if it was implied, I apologize. If your password is long, could you save it in the cookies or whatever so you didn't have to type it in everytime?
