Is it worth replacing rear R15s with R50s?
See subj... Thanks!
I can get a really good deal locally on R50's, but not sure if they will make a world of a difference in the rear.
I have RT1000p and CS400 in front.
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
B&W CDM1-SE fronts
B&W CDM-CNT center
I would think soDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
What difference would it make in the rear?
Also found a pair of R40's for the same price... Slightly smaller front drivers, same tweeters... Need more opinions.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
hey it's your system and you know your HT ot 5 channel stereo listening habits, an entry level bookshelve vs a floor stander with an extra woofer will give you more powerful sound, if you are not using the rears to much degree then keep the r15 and be happy with a few dollars still in your pocket.
I don't know you or how you listen, a question R15 vs R50, I say hell yes you will hear a difference.
read the specs on the R40 and R50 you lazy ****
it's your system and your money, do what you likeDodd - Battery Preamp
