Looking for a cheap MP3 Player ???
Early B.
Early B. Posts: 7,900
edited June 2007 in The Clubhouse
I need a 1 GB MP3 player. Just the basics, nothing fancy. My budget is less than $100 NIB. There are so many to choose from that I don't know which ones are the best. I like the ones with built-in USB ports, but most of them look cheap. Any particular brands I should look for? Any ideas?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • JimBRICK
    JimBRICK Posts: 1,543
    edited June 2007
    ipod shuffles are awesome
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • Early B.
    edited June 2007
    iPod Shuffle?
    OK. Will the iPod play WMA files directly or do they need to be converted first?
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited June 2007
    You need to use iTunes with it I think, so I will go with "no"...I had iTunes long before I had an iPod anyway though, I just like it more than Windows Media Player...
  • wallstreet
    wallstreet Posts: 1,405
    edited June 2007
  • Early B.
    edited June 2007
    OK, then forget iPod. I just want something super simple where I can doenload a WMA file directly onto the MP3 player and push "play."
    Thanks, wallstreet, I'll check out the buslink.
  • audiobliss
    audiobliss Posts: 12,518
    edited June 2007
    Well, if you open iTunes, click 'File', 'Add file', and then select a WMA file that you already have on your computer, it will add it to your iTunes library, at the same time converting it to a format the iPod will recognize and play. Then when you sync iTunes with your iPod device, it will have that file on its hard drive in a format it'll play, all ready to go.
    If you rip a CD IN iTunes, it will let you rip it in several different formats at different bitrates, all of which it will recognize.
    So, whether you're adding something WITH iTunes, or adding something to iTunes ALREADY on your computer, it'll still work. And it's *almost* as easy as just 'click and play'.
    The only thing I've tried to do with my iPod that's posed a challenge is putting DVD's on it. And let me tell you, THAT's a challenge. And I must admit I've given up. It's just not worth the headache.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited June 2007
    Sansa players from SanDisk are pretty decent and have a tuner built in! No iTunes BS either.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • POLKOHOLIC
    POLKOHOLIC Posts: 407
    edited June 2007
    audiobliss wrote: »
    not really a challenge. just time consuming.
  • POLKOHOLIC
    edited June 2007
    http://www.amazon.com/SanDisk-SDMX4-2048-A70-Player-microSD-Expansion/dp/B000ETXOC8/ref=pd_bbs_sr_3/002-0497470-9217629?ie=UTF8&s=electronics&qid=1181361507&sr=1-3
    this isnt bad actually. you can do videos as well as FM radio
    Technical Details
    Sleek, ultra-thin digital audio/image/video player with 2 GB of flash memory
    Compatible with MP3, WMA, and WMA-DRM10 music files (PlaysForSure)
    FM tuner with record capability and voice recorder; bright 1.8-inch color TFT LCD
    Convert most popular video formats (MPEG-4, WMV) to play on device
    User-replaceable rechargeable lithium-ion battery for up to 20 hours of life
  • audiobliss
    edited June 2007
    Well, on my part, it's challenging. I've yet to find a combination of ripper and converter that will actually work.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Refefer
    Refefer Posts: 1,280
    edited June 2007
    audiobliss wrote: »
    I use Final Cut Pro, which works swell. Should only put you back $1300 :D
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • audiobliss
    edited June 2007
    Oh, ok, cool. Send me a copy, and I'll let you know if you made a good investment when you purchased it (or made a good risk when you put a company program on your home computer). :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2007
    I just got this player in the 6gb variety from a member here. I loaded 405 songs on it using WMP. You can synch it to WMP & it will copy whatever songs are on your hard drive. It sounds good (with good earphones) & is easy to use!
    POLKOHOLIC wrote: »
    Technical Details
  • cfrizz
    edited June 2007
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited June 2007
    Another vote for the Sansa. It is inexpensive and sounds pretty good, especially compared to some other cheapies I listened to. It also seems to be pretty durable, my 8 year old has had one for about a year. Good battery life and runs on regualr batteries.
    You can drag and drop files on to it but if you want any meaningful type of organization to your music, you're going to need to use WMP. Display is pretty basic but fairly easy to use.
    DJ
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
