Behind TV Lighting
BaggedLancer
I know that some of you have done this but apparently the search feature is failing me, tried TV lighting and mood lighting and different combinations of the like but still nothing.
So, I know some of you have tubes behind your TV to create a backlight....what did you use? I am looking for something bluish and relatively inexpensive.
What did you use?
How did you hardwire it?
Do you like it?
Please post pics if you have any. Figure might as well add some lighting since I'm going to have the walls down anyway.
Thanks,
BL
What did you use?
Do you like it?
Thanks,
BL
Post edited by BaggedLancer on
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Exactly the thread i was looking for. Thanks. -
I picked up a small 2' skinny flourescent tube light like goes under a kitchen cabinent and put it behind the plasma. Great addition!
