My New Setup!!!
rpearlberg
rpearlberg Posts: 25
edited June 2007 in Speakers
So far this is what I have....
Onkyo TX-SR605
Polk R50's (front)
Polk R150's (rear)
Polk Csi25 (center)
what else do I need? a sub?
what kind of sub should I get, not too expensive...
Thanks...
Samsung LNS4041D 40" LCD
Onkyo TX-SR605
Polk R50's
Polk R150's
Polk Csi25
Post edited by rpearlberg on
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    yes you will need a sub, it will cover the lower Freq. better then your speakers. Congrats on your new setup. Enjoy
    engtaz
  • rpearlberg
    edited June 2007
    What do I need to hook all this up? Just regular 14guage speaker wire...do i need any clips or plugs?
    Onkyo TX-SR605
    Polk R50's
    Polk R150's
    Polk Csi25
  • lanion
    lanion Posts: 843
    edited June 2007
    From www.bluejeanscable.com
    "To Terminate or Not?
    While it's common to use banana plugs or spade lugs to terminate speaker cable, one option worth considering is simply using bare wire termination--just buy the speaker cable raw, strip the ends, and insert them into the side holes in the binding posts. Whether this will work in your application depends largely on how big the holes in your binding posts are, and whether you can successfully access them to get the wire properly inserted (not an easy task on many surround receivers). When it's feasible to do, we like to use bare wire termination because it's simple and inexpensive, and because it avoids making additional connection points (e.g. wire to banana plug) which can fail.
    The only caveat is that over enough time copper wire will oxidize and the conductivity will go down. Copper oxidation takes many years, at which point you can just cut the wire down another inch.
    My Iron Man training/charity blog.
    HT:
    32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
