Amp hum issue
Schwingding
This is weird.
I moved an Onix SP3 upstairs into the bedroom from where it was running off of a dedicated circuit in the basement.
Connected to nothing other than a pair of speakers, it produces an audible hum in the speakers whenever it is powered on.
It does this with the 3 pronged plug, AND it does it still with a cheater plug that doesn't use the ground. WTF?
There are lots of other things on this circuit that might cause a hum - 2 ceiling fans with IR remotes are prime candidates. But still, it does it even with the ground disconnected/cheater plug.
Any stabs at a solution? For the record - the Jolida did not hum in the same position.
HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee
Yamaha 5990 AVR
Onix SP3 tube amp
Polk CSi5 center
Bedroom rig
Onix Ref 1 monitors
Velodyne minivee
While doing reasearch for my system I found some information about "ground loop" problems in the Outlaw 200 mono block manual. Maybe this is something you can apply to your situation.
It doesn't know the words.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Thanks ejd. There is no ground loop issue present in the audio rig - the amp is the only device connected to the speakers. It hums without a CDP or anything else connected to it, or to that same receptacle.HT/music rig
Yamaha 5990 AVR
Onix SP3 tube amp
Polk CSi5 center
Bedroom rig
Onix Ref 1 monitors
Velodyne minivee -
Is there electrical interferance?
I used to have a computer close to an electrical room and the monitor would act all crazy because of it.
i moved the monitor to the other side of the desk and the problem went away.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Does it hum with the ceiling fans off?
Either way, it's not a ground loop issue. -
By chance can you plug into some sort of power filtering conditioner and see if that makes any change.Shoot the jumper.....................BALLIN.............!!!!!
I'd suggest the same.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
That'll be my next step - a power conditioner of some sort but I have nothing at present.HT/music rig
Yamaha 5990 AVR
Onix SP3 tube amp
Polk CSi5 center
Bedroom rig
Onix Ref 1 monitors
Velodyne minivee -
Again, does it hum with the ceiling fans off? How about with all the lights off?
If you take the fan out of the circuit, the noise will go away.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Yes, it does hum with the ceiling fans off, but you gotta realize that you can't really turn these fans off. They have constant juice to the IR receiver for the remote (just like your TV and other devices with remotes). I've discovered some pretty screwy wiring in my house and wouldn't be surprised if this same circuit ran all over the house.Again, does it hum with the ceiling fans off? How about with all the lights off?HT/music rig
Yamaha 5990 AVR
Onix SP3 tube amp
Polk CSi5 center
Bedroom rig
Onix Ref 1 monitors
Velodyne minivee -
There you go. -
I think my first step would be to plug the unit back into the original outlet in the basement using an extension cord. It's fast, it's simple and it's cheap. This will instantly revile how dirty the circuit you want to use is. Or, indicate a possible outside influence such as magnetic fields or solar flares.:D
Also look for fluorescent or any other lighting with a ballast, as well as dimmers. These are rare for receptacle circuits, but possible.The Escape Pod Equipment
Samsung HL-S5679W
Sony STR-DA5200ES
Outlaw 7125
Sony 60GB PS3, Blu-ray Disc
TiVo Series 3 HD
Universal Remote Control MX-900
Polk Audio LSi9 ebony, fronts
Polk Audio LSiC, center
Polk Audio LC65i in wall, surrounds
SVS PB12-Plus Piano Black
Outlaw PCA interconnects
BetterCables for HDMI & SUB
Master Bedroom
Sony KDL-46XBR4
Sony 40GB PS3, 2nd Blu-Ray Disc
Polk Audio i-Sonic
