Lsi15 power concern
Have been considering purchase of lsi15 however understand AVR may not power them properly, in your opinion how well would a Pioneer Elite AVR rated at 140wpc into 8 ohms work. Thanks Jerry
Post edited by jerry22m on
You understood right.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Try the search at the top of the page,you'll find all you need to know about power and the LSI line.And welcome.HT SYSTEM-
lsi 9's -
It looks like that would be the flagship of the Elite line. I am sure it will run them, but to get the most out of the 15's, a separate amp would be best.
If you got a 2 channel amp and ran the 15's off that and ran the rest of your home theater off the Pioneer I think it would be a much better solution as you would be removing the hardest to run speakers from your AVR leaving more power for the rest of the speakers in your setup.
You could always purchase it and the LSi line, run them together, and when you want\need to upgrade purchase the amps. (I would just get them up front, but it is your system)
Michael
First off welcome! Stay awhile; you'll enjoy it.
Regarding what Michael said; +1000, he's absolutely right. Give those 15's some power!Home Theater
Chane A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
2 - Channel
Polk RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
Premier Rack|Blue Jeans,Audioquest,Monster Cables| -
Thanks for your replies, saw over at the Polk web page recommended amplifier power for the lsi15 is 20 - 250 W/channel what are they talking about there? Jerry
The Pioneer Elite series is rated for use with speakers from 6 - 16 ohms. The Polk LSi is a 4 ohm loudspeaker.
You can certainly use it and may never have a single problem but you are going against the manufacturers recommendations. You can easily integrate an outboard amplifier, 'insert brandname here', using the pre-outs on the AVR.
Good luck.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
take those reccomendations with a grain of salt. My 15's are getting 500 a channel into 4 ohms from my carver and dont strain at all. Doro brings up a good point about the ohm rating of the AVR, I think the 4 ohm LSi's might yank power out of the reciever faster than it would like. watch the temperature, and give that reciever room to breath.
remember, underpowerng a speaker is more risky than over powering. if the amp clips, that can cause problems, so dont go nuts with the volume, if you hear distortion at all, back off fast.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
