Atlona/gefen video scaler for sale, Rca rgb to component video converter
louthewiz
I have a video scaler that will upconvert 480i via s-video and composite video to 480p/720p/1080i via Rgb or component video with remote 3 months old .
I used it for upscaling my std def dishnet work to my PJ and it works great with a smooth clean picture. it comes with breakout cable....
$110.00+ 3% paypal fees Sold!!!
Details here:
http://www.lenexpo-electronics.com/ATLONA-VIDEO-S-VIDEO-TO-COMPONENT-CONVERTER-SCALER-p-16382.html
Atlona Video / S-Video to VGA or Component Video Converter Scaler. Model: AT-AVS-COMP
The Video and S-Video to VGA or Component Video Converter is a unique device that allows older analog devices to be integrated seemlessly into the modern home theater. This Converter/Scaler connects composite video or and s-video to displays with VGA or Component Video inputs. Atlona Scaler will allow analog video devices to perform at HDTV resolutions such as 1080i or 720P via VGA or Component Video interface. Change inputs and resolution with a remote control included with this converter.
User Instructions:
Connect Composite Video and oand S-Video cable from an analog video source to the converter. Take VGA or VGA to Component Video cable to from the converter to your HDTV display. Use remote control to adjust resolutions, change inputs and adjust colors.
Package Contents:
Video / S-Video to VGA or Component Video Converter/Scaler
Remote Control
3ft Composite Video Cable
3ft VGA to Component Video Cable
5V Universal Power Supply
Users Manual
Features:
Supports Computer Resolutions up to 1280x1024
Supports HDTV Resolutions up to 1080i ( 1920 x 1080 )
VGA or Component Video Compatible
Supports 50Hz to 60Hz frame rate conversion.
Video quality improvement:
Black level extension.
OSD menu for picture quality adjustment.
Built in 8-bit DAC for RGB or YPbPr output
Front panel and IR remote control.
Automatic NTSC/PAL video format detection and switching.
Specifications:
Video Input signal levels: 75 ohm
Output Fomat: RGB or YPrPb
Output Connector: HD15 ( VGA or Component Compatible )
Power Supply: 5V DC Universal 110/220v
Weight: 4LB
Dimensions: 5” W x 5” D x 1 1/2” H
Item #2
I also have an RCA Rgb/Vga to component video converter that will output any resolution to component video cable, with this item you can route your computer to your hdtv easily.
$80.00 obo plus 3% paypal fees
Details here:
User Instructions:
Package Contents:
Remote Control
Users Manual
Features:
Specifications:
Weight: 4LB
Item #2
My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Post edited by louthewiz on
Price lowered...My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
price lowered againMy gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Price lowered ,last call before going to the bay.My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Now at ebay with a low reserve price.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=015&sspagename=STRK%3AMESE%3AIT&viewitem=&item=250129648455&rd=1&rd=1My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
