Adding a 2nd Sub
Sherardp
Sherardp Posts: 8,038
I'm now ready to add my second sub, I was going to go with another PB12 Plus 2, however I have been reading awesome reviews on the JL Audio Fathom 113. Has anyone heard or demoed this sub? Any suggestions, recommendations would help.
Post edited by Sherardp on
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited June 2007
    Every review I have read about says it's phenominal. Is there a 30 day trial?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • MikeC78
    MikeC78 Posts: 2,315
    edited June 2007
    I'd personally wait until the new Ultra starts shipping in July, and the reviews start comming.
    The word on the street is that the new ultra will have a lot more output from 20hz and under, and about the same in the higher octaves. All for about half the price.
  • Sherardp
    edited June 2007
    MikeC78 wrote: »
    Good point I forgot all about the new SVS lineup coming.
  • Schwingding
    Schwingding Posts: 363
    edited June 2007
    I would not buy a 2nd sub that does not match exactly the frequency response and output of the first sub. When you get into EQ'ing dual subs, it is nearly an impossible job with duals. The BFD does have 2 EQ engines, but REW has no facility to eq dual subs and anything you do to one sub will affect the room performance, **** up the other one's curve. It is a tough job to say the least. With two identical subs you can apply a single curve.
    I've heard people say you can smooth out frequency response with a 2nd sub of a different make/model, but it is definitely a harder job.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • engtaz
    engtaz Posts: 7,664
    edited June 2007
    go for it.
    engtaz
  • Face
    Face Posts: 14,340
    edited June 2007
    With a SPL meter and the right software, it's not difficult to tune in two different subs. It's just time consuming and can be back breaking moving them around. :D
  • ohskigod
    ohskigod Posts: 6,502
    edited June 2007
    2 different types of subs can be done, but face is dead on when he says its time consuming to get them to do what you need in harmony in a room.
    some will say stack, but it didnt work out too well for me, so I had them in 2 different parts of the room, made balancing it out easier.
    once I changed my sub driver in my diy box to a SVS plus, no 2nd sub was needed.
    of course, I gotta ask how the hell a pb plus 12 isnt getting the job done, are you trying to pressurize a cave or something :D
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • Sherardp
    edited June 2007
    no not at all, room is 20x20 I just wanted to add a second sub to balance things out and of course so the bass is felt even more.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2007
    Ask Ed Mullen...he recomended adding a Plus to a Plus/2 for a guy on AVS that had great results...I believe he's running them in the same tune (20hz), but differing gain. Got a very flat response utilizing a SMS. I'm running the 20-39+ and DIY+ and got a much flatter response with some pretty astounding bass levels when it's called for. I imagine a new Ultra with the Plus/2 will work with a bit of tweaking.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • engtaz
    engtaz Posts: 7,664
    edited June 2007
    I run 2 sub with great results.
    engtaz
  • THX 3417
    THX 3417 Posts: 219
    edited June 2007
    Why not 16 subs! Hell yes if the EMPIRE in Leicester square is using 16 JBL 4645C for as part of there THX sound system with 20KW in the sub bass department not to mention the whole system is a powerful 56KW:eek: :D .
    So the more subs and the more attention to tuning I’d say you’ll collapse the foundations of your home around ears.:D
    The more you add the lower it will go as well as playing very loud, but it’s the depth you want that is what you’re aiming for. But please remember not to let the sub bass overwhelm the rest of the sound system it should merely accompany it not smear it without colorization of the sound.
  • Grimster74
    Grimster74 Posts: 2,576
    edited June 2007
    Hey Shep, why not just order another PB12-Plus/2? After adding my second, I'll never look back. In my room, which is 14' wide, 24' deep w/ 8' ceilings I've actually had my teeth rattle together while watching the glass tap scene in Finding Nemo.
  • Grimster74
    edited June 2007
    Ron Temple wrote: »
    To add to what Ron said, one of the best investments I've every made was adding a SMS-1 for the dual subs. Just being able to have total control over just the SUBS on the fly I think is a real benefit. If you have any questions about the SMS-1, you know how to contact me. Later Bro.
  • Sherardp
    edited June 2007
    Grimster74 wrote: »
    Agreed I just emailed SVS for shipping quote, I will order the sub and SMS 1 while Im out on business the rest of the month and have something to look forward to upon return next month when I get back.
  • Grimster74
    edited June 2007
    You won't be sorry.
