MOMO Depth Dilemma
Systems
Planning to purchase MM 465 Component Systems (6.5")
I have a Honda Accord Coupe 2000 and I've read several places that my mounting depth for the front door and rear deck is roughly 2 inches.
On inspection of the specifications (depth), it's 2.81" for the tweeter and 3.06" for the woofer, which are humongus. Can I somehow fit them in? Or will any effort me detrimental to the
Thanks,
Chris
Thanks,
Chris
Testing
Testing
Testing
Testing
Testing
Haha... that all just went over my head.
Anyway, I was just wondering if it was possible. So that would be a yes, thankyou for your prompt reply.
Do most Car installation places offer these kind of tools and kits?
Or are they home crafted stuff?
ChrisTesting
Testing
Testing -
YOU CAN UNSCREW THE BACK OF THE WOOFER. I MIGHT HAVE TO DO IT IN MY CAMRY TO GET MY 6.5'S IN.osiris
