Something wrong with amp, I think
donedroolin
donedroolin Posts: 225
edited June 2007 in Electronics
Think I posted this before in wrong thread. I have the Parasound A51 amp and C2 controller. I am not getting any sound out of my front speakers or the center , only sound is from the rear. I checked all the connections. Amp and controller hooked up useing XLR cables and all the speaker wire with banana plugs all tight.tried two sources my DVD and the Sirius satalite, still only sound from the rear speakers. Any suggestions . Thanks for your help.
TV- 52 inch LCD SONY BRAVIA XBR6
TV- 42 inch PLASMA HITACHI ULTRA VISION
AMP- PARASOUND HALO A-51
CONTROLLER- PARASOUND HALO C-2
FRONT SPEAKERS- LSi15's and LSiC
REAR SPEAKERS- LSi7's
SUBWOOFER- VELODYNE DD15
BLU RAY- LG SUPER BLU BH200
BLU RAY- SONY BDPS350
GAME SYSTEM- NINTENDO Wii
MONSTER POWER CONDITIONER
WIRES- AUDIO QUEST and MONSTER
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2007
    You posted in the wrong section (again) - this should be in the Troubleshooting section.
    Also, posting brand and model number usually helps.
    If you are sure that you haven't 'disabled' any options in menus, then you will need to contact the manufacturer or the audio shop where you bought the amp to get it repaired.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • venomclan
    venomclan Posts: 2,467
    edited June 2007
    ViperZ wrote: »
    Parasound A51 amp and C2 controller, I think that qualifies for brand and model #.?
    donedroolin, If everything is hooked up correctly, there can only be a problem with the pre/pro or the amp. I doubt you have 3 blown channels, but to be sure you can hook up your rear speakers outputs to the other channels to test.
    Chances are you have something misconfigured in the menu giving you only surround sound. Be sure you have all inputs set to balanced (XLR), on my stuff it is a separate selection called B1. Also try a 5 or 7 channel stereo selection to make sure it is not the amp or your hook ups.
    If all else fails, check your manual.
    V
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2007
    I would check all the settings in the pre/pro carefully. I would also try switching channels on the amp (temporarily) and also try switching speakers too to determine if the problem lies in the amp, pre/pro, or elsewhere.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
