Can I Amp My Components Using An Amp Without A High Pass Filter?????????????
iwtmkc
iwtmkc Posts: 1
edited June 2007 in Car Audio & Electronics
I have a set of Polk Momo MMC6500 components. I want to use a 2 channel amp that I have already, but someone told me that it may not sound good because the amp doesnt have a high pass filter..... but isnt that what the crossover is for??
Post edited by iwtmkc on
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2007
    Total bunk.
    The MMC6500's come with a set of passive crossovers designed specifically for the MMC6500's. Simply hook the amp up to these and youll be set.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited June 2007
    Guy probably meant that they wont sound good running them in full range off the amp. If you do not have a sub, don't worry about it. I have run my components full range plenty of times when I took out my sub.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
