denon POA-5200 vs adcom 535
dougr
any thoughts on the relative merits of these two amps for driving RT16s?
Thanks,
-Doug
Thanks,
-Doug
______________________________________________
RT16 x4, LS/fx x2, CS350 x1, HK247, B&K av5000, B&K avp-2030, pio bdp-51fd, InFocus X10 and a $13 sheet of doable
I have the Adcom 535 and used to own the RT16's. While the Adcom is a great, underated amp, I do not think it will be enough for the RT16's. The bass will be muddy underpowered. I do not know wabout the Denon.
Check out some used Outlaw or larger Adcom amps to run with the RT16's.
V -
I like the Adcom 535 I had. It certainly had more balls than it's ratings gave it, and I liked its sound very much... that said, for home theater, the Adcom despite is pro's is being compared against an amp rated at 3 times its power.
If quality is your goal, I'd certainly give the adcom a listen. However, if power is, I don't know enough about the Denon to say it was a sure buy.Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II
