Tinny Amps Size wise. Need Sugestions
Jonboy
looking for suggestions on a small amp. Size wise needs to be very small. 2 or 4 channel. Really dont need alot of power so 15w to 20w RMS would be plenty. Older amps are fine.
Post edited by Jonboy on
If Hifonics is still building thier Warrior series, they will fit the bill nicely.
Kenwood has some small amps as well as Profile.
Alpine used to have some dinky amps too but I don't know if they still do. They are worth looking at though.Expert Moron Extraordinaire
http://cgi.ebay.com/CARVER-PMA-2022-car-amplifier-BRAND-NEW_W0QQitemZ170106656713QQihZ007QQcategoryZ39732QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
check this one out. carver amps are some of the best made. very clean and bulletproof. this would be a great choice at a great price.kenwood excelon kdc-x991 h.u.
Rockford Fosgate 360.3 DSP
Rockford Fosgate POWER1000 running entire system
Image Dynamics IDQ12 Sub
Morel Elate 6 front stage -
That is a nice deal but the only problem is that there is very little support out there for it. You can't get softcopies of manuals anywhere. There are plenty of wee little amps with way more power than one would expect out there on the used market but becareful what you get. That Carver is a simple, standard hookup that you see on everything now. Other stuff may not be such a simple hookup. The older it is the more of a chance you have of just bundles of unmarked wires hanging out. If you don't know what the wires are or what the pin outs are, you are going to have a hell of a time getting it hooked up right.Expert Moron Extraordinaire
check out Alpine's PDX amps and MB Quart's new line.
http://ikesound.com/product-product_id/4794
http://ikesound.com/product-product_id/5058
those are about as small of 4 channels as you'll ever seeThe Artist formerly known as PoweredByDodge
