yamaha saovo 1
JimBRICK
JimBRICK Posts: 1,543
edited June 2007 in Speakers
http://www.yamaha.ca/av/speakers/Soavo/one.jsp#specs
went to a local shop that sells yamaha and I must say they sounded pretty good even in comparison to the paradigm studio series I heard
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Try other brands to compare.
    engtaz
  • cmy330go
    cmy330go Posts: 2,341
    edited June 2007
    I've heard from CP member Spacedeckman (Yami Rep) that some of the higher end Yamaha speakers are pretty respectable. I just don't know of any place to listen to them.
    Maybe he'll chime in.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • JimBRICK
    edited June 2007
    2 CHANNEL
    Under construction
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2007
    They are pretty lightweight for a tower speaker. If my converter was right they only weigh a little over 29lbs.
    The LSI 9's weigh in @ 33lbs, & the 15's weigh in at 66lbs.
    The RTI 8's are around 50lbs
    Heck my old RTA-8's weigh in at 39lbs.
  • Poee7R
    Poee7R Posts: 906
    edited June 2007
    The .pdf shows them to be 27 kg/59.5 lbs.
    Dave
    Once again we meet at last.
  • JimBRICK
    edited June 2007
    1 kg equal 2.2 pounds
    2 CHANNEL
    Under construction
  • cfrizz
    edited June 2007
    I guess the converter I used got it wrong. Why can't they use both metrics & pounds?
    Actually maybe not. I just went by what the link page said:Weight 13.5 kg (ea.)
